Hey Guys,
so i pulled apart the hydraulic lifters for a clean as some were very noisey.
i basically followed this - http://www.gtrpwr.com/showthread.php?t=726 except i cleaned them individualy and left the lifters sumerged in motul 6100 15w50 oil for 48 hours, then put the lifters back into the spots they come from.
now after installing everything and checking timing about 5 times i have no compression in any cylinders..
if it possible that i have blead the lifters to much or am i missing something here?
That guide is correct way to do it, ive done a few sets exact like that with no problems. If you followed it then lifters shouldnt be the problem but hopefully its not the timing or else going to have some mashed valves.
the more i read around the different forums, some are saying to not pre prime the lifter before assembly, to let them prime once in the head?
i had a similar problem, poured a little bit of fresh oil into all the lifters before putting them back together and 1 ended up having too much and refused to bleed down, causing no compression on that cylinder. pulled it all apart and replaced the lifter with a spare and problem solved
i managed to figure out wtf i did wrong..
very stupit mistake.. when i was assembling the lifter bodies i managed to put them the wrong way around which is why they could no bleed down.. i i didnt put the check vavle side into the lifter body, but the other way around.
we dont believe it has done any valve damage but will know more later today :ph34r:
I havent cleaned mine as they were already clean, not knowing any better i hit them with compressed air and blew the old oil out after a soak in petrol. I hope I havent damaged them? a few were pumped up by air, will this bleed out or is this bad? engine not started yet. Any info would be good thanks
Bleeding air/oil out of lifters;
Pull lifters out of buckets, push a pin/ paper clip into the ball bearing part, afterwards it should compressby gently squeezing it, if it doesn't, it either has oil or air still in it
Leave in oil over night or put in and crank motor until you get oil pressure then start the car
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
