Hy buys just found out my r33 series 2 turbo is blowing smoke and I have a choice of rebuilding the stock one or rebuilding a stock gtr turbo ( which I would think would be better??)
Any way I'm after some info on prices and brands or people who do it thank kind of stuff
I'm moving to canberra in 10 days and I want to try and get it done there
I also thought if I get the gtr turbo rebuild I don't have to take my car of the road at all but to swap it over once rebuilt
Do gtr turbos bolt to a standard rb25det exhaust manifold?
https://www.sau.com.au/forums/topic/387864-turbo-rebuild-help/
  • Replies 40
Or is it just not worth it??
Simply not worth the effort.
People have tried - most say they wouldn't do it again simply due to the stuffing around.
Adaptor plates need to be made, the whole intake/exhaust side. All for what? Two turbos that have ceramic wheels - if they fail bye bye motor.
It'll be a min $5000 job as you'd put two proper turbos on ($2500). That's just before you start.
i might just get mine rebuilt i think or maybe upgrade to a r34 turbo i have all the normal mods fmic turbo back exhasue boost controller and upgraded pump i was hoping to get mine rebulit or just a small upgrade to a r34 turbo do r43 turbos bolt up? and are they much better then the t3 standerd turbo
Getting back to your original comment that your turbo is blowing smoke. I have no idea how you have reached this conclusion but I would stop yourself from buying anything until this is diagnosed correctly. There is no point replacing parts until you know what actually needs replacing.
Describe the conditions under which you see smoke.
iv had the turbo looked at by my mechanic and he said that there is shaft play and the bearing have gone and you can even hear the noise the bearing are making :( sounds like when you pop a bearing in a skate board
wheel
Edited by wilderboy
Is it still making boost? When can you hear the bearing noise?
I have read so many threads like this over the years and stock turbos are either working or the turbine has gone down the cat.
If you want to upgrade you really need to take the time to search SAU as there are so many threads devoted to upgrading turbos.
Try searching with 'hiflow' 'hypergear' 'gcg' as a starting points if you are determined to replace the turbo. The R34 turbo isn't much of an upgrade btw.
Im still pretty new on this site, let me answer this one lol
Option 1 - upgraded turbo = Tune, do u have a aftermarket ecu, if not ur up for about $5000+ (new turbo, ecu and tune)
Option 2 - rebuild stock turbo $800 approx ?
Option 3 - second hand stock turbo in good cond $400 approx.
How'd i do ?
chirs that kinda goes with everything i have read about and im not really up for a hi=flowed as its just my day to day car and i was thinking a r34 turbo would be a little better then the stock r33 turbo but wont hurt the bank to much
Id prob forget the R34 turbo idea, Get urs rebuilt, add a manual boost controller, Its easy, theres a DIY guide on this site. Run 8-10 psi and enjoy the extra lil bit of power. Then u wont need to worry about another turbo for a long time unless u wanna upgrade
Edited by chris_82
and you can hear the nosie the most when its boosting
That noise could be anything from a intake leak to turbo/manifold gasket leak.
Perhaps you should (or your mechanic) should thoroughly inspect for this first before you spend money changing turbos.
Once again the R34 turbo has a slightly larger turbine and will make almost no difference on a stock car at stock boost with a stock ecu.
The problem as I see it is that paying to get an R33 turbo rebuilt to standardish specs (but obviously not ceramic spec) will cost almost as much as a Hypergear hiflow. Now that seems like a silly idea. To spend that much I'd want to come out with the hiflow at least. So the alternative comes down to buying a secondhandy. Now, an R34 turbo will cost a little more than an R33 one, but can be up to several years younger and is a slight upgrade. So to me, it kaes sense to use one of those rather than an R33 turbo, unless you happen to fall backwards onto a really good R33 one for not much coin.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
