Price $6500 (willing to negotiate in person)
Located in canberra but would be happy to organise transport with buyer.
great car for daily duties or great platform for a track car
car does not run the best under load at the moment because the Haltech maffless ECU needs the fuel mapping to be tuned properly but i have been driving it around town and keeping it under 3500rpm and it is not an issue that needs addressing right away.
it went in for a roadworthy inspection last week but got knocked back because of the front mount intercooler and atmospheric blow off valve. it would cost about $300 to buy the standard parts to pass rego but there are plenty of members willing to lend out bits.
any questions please email me at [email protected] or txt me on 0422626173
R32 GTST Manual. Wine red (AN0)
RB20DET
RB25 turbo 13psi
Split dump exhaust with 2 mufflers and a silencer for rego( not to loud but free flowing)
195kw atw
Haltech Computer
GTR front bar
GTR wing
Coilovers front, Nismo rear suspension. Solid mounted rear.
18x8 front and 18x9.5 rear Starcorp Impul
Custom cushion button clutch.
Alpine Head unit, 7in fold-out dvd/tv screen. Subwoofer. Focal front splits and tweeters. Sony rear speakers.
Hicas lock bar, all lines and solenoids removed.
have a set of brand new rear wheel bearings and the standard intake piping and hosing
Recently done rear brake pads, oil,coolant, spark plugs, fuel filter and injector cleaner and brand new 550cca battery
https://www.sau.com.au/forums/topic/387889-act-r32-gtst-type-m-6500/
  • 3 weeks later...
fuelling issues have been fixed so now it drives great. at first i thought it was the fuel mapping but it turned out that the fuel pump was shot. it now has a new Bosch 040 with new relays.
once it passes its roadworthy inspection i will put the front mount intercooler back on along with the BOV and maffless intake pipe and take it for a dyno evaluation.
how do i edit the main add because i need to change some information
Fwiw, I knew this car from around 2005 - 2010. A friend owned it for a couple years, then sold it to another friend who later sold it, probably to this guy?
It was a good honest car back then. And always looked after. I've probably done 10,000 + kms in that passenger seat...
lol im still wanting to see the dyno sheet for that 195 atthe wheels :whistling:
it's really not that unbelievable seeing as it has everything you just said plus an rb25 turbo.....
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
