  • Replies 212
Posted Images
I'll be there from around 8:45 am guys, Do you want me to get in touch with the local highway patrol down at the school so we don't have any hassles like last time with the motobike? And we will be pulling over just after the set of lights and merging lane onto the highway to regroup, Everyone make sure we have enouph room for everyone to fit in, and be aware it turns into an 80km/h zone at the campbelltown exit for roadworks, so there won't be a near miss next time because of a stupid merging L plater.
im wanting to organise one for the 4th febuary. but i think ill slot in with you guys, i live in gosford and i normally bring about 5-10 cars. we usually start at livo KK's (we can start at casula kfc if u wish ) take heathcote road to the princes hwy, turn left a few kms up the road on the right is farnell road. travel down through the national park, rainforest aka sir bertram stevens drive,
stop at stanwall park for a toilet stop then follow the water down through throuill, russellvale, mout oseley and get on the southern freeway down to albion park rail go behind the airport and up macquarie pass to the pie shop
after that either go back up mount ousley/picton road/ princes hwy or
down to kiama for some blow hole / car photo ops. then come home our own way.
do it that way its about a 600km trip from gosford. but is always a cruise i enjoy going on alot like putty road. but each have their own ups and downs.
LOL OWEN! you better come man, your happy smiles and waves make the cruise awesome! as well as the pies!
Will do my best. By March the R33 should be on the road again, so I might go down early and meet you guys at AP as usual. Failing that, I'll be at Casula in the commo (living in Liverpool now)
hi juz, looking forward to robertson pie shop cruise, this being my first attempt at a skyline aust outing,i do drive a r33 skyline 315kw at rear wheels. so some mods have been done the downfall of this is iam 65yo in a crises and cannot get enough of skyline power ,even though i have had this car from new, regards laurie.
Hey Man, If you already haven't noticed SAU is one of the best car community's we have here in Australia, I Started here as Terry and owen would remember I was coming on cruises before I got my L's (mum drove) And I still had a great time talking and meeting everyone! So Come along and have a chat with like minded people!
Guest
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
