Skid pans 27th January 2012 Drift your car or ours
Drift . Skid pans
drive your car or drive ours
EASTERN CREEK – 27th jan 2012
we will be doing the wet skid pan and the skid circuit (fig 8 /peanut)
The fusion sound off and show n shine will also be there
if you have questions hit us up
[email protected]
1. Organizing Club: DRIVING SPORTS .INC.
2. Type of Event: Drift, Driver Training.
3. Date: Friday 27th jan 2012.
4. TIME: Scrutineering starts from 4:45 pm drift starts 6:00pm end 10:00 pm
5. Venue: eastern creek skid pan and fig 8
6. Track Surface: concrete (wet) Direction: clockwise
7. Event Format:
Skid circuit (fig 8 dry)
Cars will be divided into groups based on previous drifting experience In the event that a driver has not competed in this type of event before, he / she may be placed in the “First Timers” groups, to determine their appropriate group, proposed time of each session is 4 mins. All drifting will be non competitive.
Skid Pan (wet)
Cars will be divided into groups of 4 based on previous drifting experience
a) Maximum number of Driver entries for the wet pan is 32. Max for the fig 8 is 18 , you can swap when you like
b) Maximum number of Drivers per entrant is 2.
c) Entry fee $150.00 +$57.00 cams licence if u don’t already have one , $110 for members
d) passengers $50 ( passengers on wet pan No cage , passengers on fig 8 need half cage minimum )
e) Opening date – open
f) Closing date – 27th jan 2012
g) Entries will be accepted in order of receipt, accompanied by the appropriate entry fee.
h) Bank Transfers being the primary method of payment. Or cash on the day
A 1 Kg CAMS approved Fire extinguisher is recommended
To book follow this link http://www.drivingsports.com.au/entrant-form.html
Fill in the entry form
if you would like to pre pay , bank transfers will only be accepted up to tue the 24th of jan 2012
The Club has no facilities for Credit Card payments.
Here are the Bank details: -
Bank: Bendigo Bank
Account Name: Driving Sports
Account Number: 137911822
BSB Number: 633-000
We will also be trialing a few new things on the fig 8 and wet pan , but most sessions will be as normal
Entry for spectators is free so come check it out
Friday night sliding
see you there
i went to one a few weeks ago, entry for spectators was like twenty bucks :(
was a driving sports day but i spose they were using the main EC track too which gave more bang for buck, still felt pretty ripped off considering it was basically just a track day and not any kind of official event.
anyway hope to be at this one, always fun to watch.
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
