I'm concerned that my car is too low(was like that from Japan). I can barely fit my little finger through the gap between the guards and the tyre. I can fit a coke can under the car(standing up of course) at the lowest part so should be legal ride height.
How do Cops usually measure a car to be "too low"? Detailed explaination would be appreciated. Also I want it to handle at its optimum so is there a way to determine optimum ride height? Is optimum ride height based on damper and rebound of the shocks or am I looking at totally wrong areas?
https://www.sau.com.au/forums/topic/38796-optimum-ride-height-for-r32-gtr/
but not sure.
Dont know what the OEm ride height is..
A few of the guys run 340-345 front and 340-350 rear. I tested our Targa Car the other day at 335 front and rear with DMS suspension, and it seemed OK, in fact i am tempted to run those setting in this TT.
Last year we ran Tein @ F=340 & R = 345, but the front was wrong spring rate.
Measure from centre of your wheel to bottom edge of wheel arch
As far a cops are concerned, check with the local authorities
TT
Well if that is the case, that is very low. Tein give a 90mm test bar for setting their suspension, which you put under the front of exhaust (Lowest Point)... That translates to 320mm ride height on a HCR32 with std wheels
TT
Hi ecenshu;
My R32 GTR rides about R370mm F360mm measured from hub to guard lip with standard suspension.
'Optimum' ride height will vary depending upon what you want to use the car for, however, I understand that less than 350mm measured as above will cause you to upset the dynamic aspects of the suspension. You'll also need to adjust camber if you go lower than standard.
As far as I know the cops don't measure ride height, they measure ground clearance. The RTA should be able to assist with this, about 100mm sounds right.
You might also wish to call Whiteline suspension in Sydney for advice.
Regards
Not having any real experience with 1:1 scale cars, based on my knowledge of RC cars though:
A good setup for rough terrain(public roads) would be to have the car as low as possible with while maintaining maximum suspension travel. Also, go softest you can with the dampers and get the stiffest roll bars that you can put up with...however, there is a point where it is too soft and I think the standard damper rates would classify as the softest setting possible.
Do you think my reasoning is flawed? My opinion is to get dampers that are closest to the stock settings and maybe a bit stiffer to minimise roll to a certain extent. Anti-roll bars should be the controlling factor for body roll as stiff suspension would only be useful for tracks because theres not too many weight transitions on public roads...I can only think of roundabouts and I can't picture a stock GTR suspension settings with stiffer roll bars not being able to handle them :P
Lemme know what you think...
PS: would anyone know what the lowest ride height for a R32 GTR while still maintaining about 80% of the suspension travel would be?
Hi ecenshu, my thoughts (*) on what you've written are:
* Maximum suspension travel is relative to what you want to use the car for. How much do you need? You can have the car as low as you like provided your camber is OK and the available travel is sufficient. Height and suspension travel are related in the extreme sense, but actual travel will be different for a given spring rate and length, which is related to the next point.
*The dampers should be matched to the spring rate. If the dampers are too stiff the springs won't compress or rebound. I think if you used the stiff roll bar soft damper set up you'd get either over or understeer badly (?) depending upon the set up. Camber setting will also play a big part here. I don't believe roll bars should be used to do anything other than minimise roll and control over or understeer. The rest is up to shocks, springs, and alignment. I'm fairly sure that extremely stiff anti roll bars on their own will make the car a skate in the wet.
Do you think my reasoning is flawed? My opinion is to get dampers that are closest to the stock settings and maybe a bit stiffer to minimise roll to a certain extent. Anti-roll bars should be the controlling factor for body roll as stiff suspension would only be useful for tracks because theres not too many weight transitions on public roads...I can only think of roundabouts and I can't picture a stock GTR suspension settings with stiffer roll bars not being able to handle them :)
*You haven't mentioned springs here anywhere. Don't overlook them because they've got to be considered carefully. Body roll is only one factor, without it there can be as many problems as with too much as I understand it assists weight transfer and therefore grip as long as it's withn reasonable limits for the intended use.
Sorry I wasn't clear before, or I'm probably getting my terminoligy incorrect.
Car will be for street use and pending $$$ a circuit car. I said damper when I intended to mean the whole shock assembly, ie: matched springs to shocks.
Well I guess t get "maximum" suspension travel I'd end up with a landcruiser setup! :). I would like the car to be able to handle a pothole or two while cornering hard if thats too much to ask....
Preferable setup will be "firm" ride with some roll on the road so it doesn't skate or skip over ripples. Adjustable anti-roll bar will be stiffened when minimal roll is wanted.
Does this seem I'm thinking correctly? Or should/would I need to get a firm/stiff spring/damper combination to stop/minimise body roll?
Also, is it damping, rebound or spring rate that affects how much a car rattles your bones?
PS: I'm just a dumb car owner and don't know what I mean! :cheers:
  • Like 1
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
