Hi guys
I have a 91 R32 GTR, has a fully rebuilt motor to all N1 specs. N1 Turbo's, N1 oil/water pump etc etc. Has 1500km on it. Also have a 3'' exhaust and HKS Pod filters. I'm getting it fitted and tuned with some parts soon. Feels like its runing stock boost at the moment. So not sure how much its making.
Apexi Power FC pro + Hand Controller
Apexi Boost control kit
Nismo fuel pump 276 lph
Nismo fuel pressure regulator
Sard 700cc injectors
I'm just wanting to know everyone opinions on what kind of power I will make at the wheels once I have this work done. Since I have the N1 turbos, I'll probably be getting it tuned at 15-17 psi. I Heard i'll make 250rwkw+ and then heard from other's I should crack 300rwkw.
Your thoughts???
https://www.sau.com.au/forums/topic/387994-r32-gtr-mods-how-much-power-output/
  • Replies 50
Posted Images
Around 265 depending on exhaust restrictions.
Only one way to tell for sure - tune the thing and come back with a result. Then put it in the RB26 dyno thread which is up the top of this section.
N1 is not all forged.
If it's been build to strictly N1 specs - it will still have ALL the problems that RB's have factory especially around oil control etc.
Basically you need boost either way - read the dyno thread.
Yea sorry, didnt mean all forged, just ment Pistons etc. Yea fairly sure its been built to proper N1 specs. Ohh, I really hope I dont get all those RB" problemsthen haha :(. Boost it is. Hopefully 18psi will be comfortable for it.
Edited by 91BNR32
I bought it, and the guy rebuilt it all to N1 Specs, inlcuding turbo's etc. I dont think he did the oil system which would of been smart, just has gthe N1 oil pump etc. so that's why I thought 18psi is probably enough for it. Has only 1500km since the rebuild. But you guys would know more than me.
Just wanted to see what kind of power it will make with those mods, and it looks like high 200's. maybe 300rwkw with 18-19psi.
Mine made 400rwhp at 18psi with R34 N1 turbos.
Same.
91BNR - you should have no problems getting 300kw, and you shouldn't need to add any other parts to get there. The only thing you could add is adjustable cam gears, to help low end response.
yea I thought about cam gears, not sure if really needed them though. How about the Stock R32 GTR AFM's. will they flow 300rwkw? I mean i don't wanan keep spending more money than I need too. Gotta draw the line somewhere lol. and 300rwkw would make me happy
Those turbos+ 700cc injectors and standard afms should net you 300 rwkw.. Standard afms start maxing out at around 310-320 mark
Make sure it's a safe tune, dont bash the limiter, service the engine properly and enjoy
Who's tuning it btw?
Stock injectors will be fine as well. They will run out 280-300rwkw as well. Spending $700 on injectors and not doing the AFM's is a waste IMO.
If you run out of injectors, just up the rail pressure a bit. I've managed 340rwkw out of stock injectors via a very tiny bump in the pressure. Wouldn't go any more than that but it can be done and reliable.
Thanks for the advise guys. From what people are saying, I might just leave the standard injectors and AFM's and get it tuned at 16-19psi. And just see what I get. The injectors have been Sonic cleaned, flowed & tested with new caps, so they would atleast be in good healthy condition. And the AFM's have been properly cleaned aswell. If I get close to 300rwkw with that I'll be happy. As I am on a budget, no point me spending another $1200 if my injectors and AFM's are holding up well at high 200's/300.
Power FC
Boost control kit
Nismo Fuel pump 276l
Tune 17-19psi
= See what I get for now :)
Would people agree that if I wanted to go furthur after that, it would be 700cc injectors, Z32 AFM's and Cam gears?
Cheers for all your input, helps me out alot.
Edited by 91BNR32
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
    • Right, but I thought the problem has been for a while now that even if you know manifold pressure + throttle position you still have non-linearity and aliasing issues vs actual engine load? One way I can see things simplifying is going DBW, then all air going into the engine is represented by the throttle position. As opposed to a random bimetallic strip vaguely linked to engine temperature opening and closing a shutter or some random power steering air valve suddenly allowing a bunch of bypass air. But the same throttle position/RPM at ~atmospheric MAP in different gears is not guaranteed to be same engine load? Honestly, ITBs are of such dubious value IMO. I don't know why these things are hyped up so much. The main benefit as far as I can tell is you reduce the likelihood of cross-cylinder EGR scavenging with significant cam overlap at idle. I would absolutely run speed density and be done with it if not for this fairly esoteric control problem.
    • Hah dont worry, my adult brain has this conversation every single day. Dont waste your money, invest more of it into shares, pay down the mortgage. Then the bedtime insta doom scrolling begins and after being bombarded with gtr's my mind is set: im definitely getting one! I have the current model mx5 as the weekender, but i just miss my boost and literally like your username, the sututu's that come with it. I remember with my 2nd supra, as it had twins and vvti, they used to spool real early, like 1,500rpm so you could just be a spooly boy all day long. Some people say they get over it after a while, not me tho.
    • If you need to refinance your mortgage and reset the loan terms back to 30 years and cash out on your equity for "investment" purposes *cough* car parts, I can help 😊
