Would probably wanna go a bigger set of turbos as well depending on what power your chasing
700cc injectors will tale u up to around the 360-400rwkw mark depending on who tunes it
Some people like to throw in some mild cams as well though some would say stock are fine
Probs want at least 3 1/2 inch exhaust as well
  • Replies 50
Posted Images
Thanks for the advise guys. From what people are saying, I might just leave the standard injectors and AFM's and get it tuned at 16-19psi. And just see what I get. The injectors have been Sonic cleaned, flowed & tested with new caps, so they would atleast be in good healthy condition. And the AFM's have been properly cleaned aswell.
Yep, good plan. If the injectors hadnt already been cleaned then i'd suggest replace them and dont bother with the FPR. When you do upgrade the injectors you wont need the FPR anymore, but since you're pushing the stockers to their limit, it will be useful.
Re: cam gears, sounds like you can include them now since the injectors and afms are out of the picture :thumbsup: They're not essential of course, but if you were to add them later you'll need to pay for another tune.
EDIT: If you have N1 cams, the cam gears will be less useful.
get bigger injectors incase you want to increase your power down the track, saves you doing it again.
Cam gears, waste of time as a lot of tuners dont bother playing with it. Just put in a set of Tomei Type B Poncams 260/260 9.15mm lift. :)
300awkwkw easy peasy
I'm not even sure what the FPR even does lol. Just heard the Nismo one is a good upgrade. So your saying with standard injectors, its not necessary for a FPR?
Yea still deceding. I wanted to see how these standard injectors go, since they've been all cleaned & reflowed. and I'm after 300rwkw. wont want to keep chasing more.
Yea I heard Cam gears are a bit overkill, unless your getting serious about your car. But each to their own.
Re: FPR - no, other way around. The FPR can be used to raise the pressure in the fuel rail, so the injectors flow a bit more. Its a hack, but if you only need a little more flow, its economical. If you getting bigger injectors there's no need for the extra flow from bumping up the pressure, as they will have enough flow already.
On RB26s many people have had good results using adjustable cam gears. The argument to avoid them because the tuner may not touch them, should be an arguement to get a better tuner, rather than to avoid the gears! For Cost/benefit, most setups will find cam gears a far better alternative than aftermarket cams. Anyways, they're certainly not required.
+1
Cams gears on a RB26 are the best value modification short of upping the boost, which is free.
Cam gears for sure, tuners that don't touch em are I lazy to pull the cover and adjust em. I no my tuner would pull the covers off and change em, because he no's he will get a better result by doing it. I've got a FPR on my car, rail pressure bumped up alil bit, and I make 312 kw easy, factory afms, and injectors. Don't listen to all this bullshit about changing injectors now, it won't make any diffrence.
If u are going for more power, than change the injectors, your Gunna have to get it retuned to make the more power anyway, don't waste ya money.
Get it tuned as it is. Put some cam gears on and be done with it. It will take u a lil while to get over the 300kw
Thanks Deano, Im not after more than really 300rwkw, so I like the what you said. Power FC, Boost control kit, Nismo fuel pump, Nismo FPR, cam gears, and a tune on 16-18psi. See how I go hitting 300rwkw!! :)
Don't really need the fuel pump either mate lol
It is good insurance though
Really? that saves me $500, I can always drop one in later, if I find it's not flowing enough after the tune. So all I need is the Power FC, boost kit, Fuel Pressure Regulator, cam gears. and im set. Awsome!
Hopefully on my freshly run in N1 spec motor with the N1 turbo's i'll get close to my 300rwkw on 17 psi or so.
Appreciate all in the input guys.
Stock pump is fine for your power levels, still has a fair bit in it
Also buy your parts from rhdjapan... Heaps cheaper ;) I paid 350ish for my nismo pump and 660 for my sard 800cc injectors
Hi guys, just a quick update, and just need some advise before I go spend more money lol... A background on the car.
I bought the car with a fully rebuilt motor to N1 specs. Has 2000km on it. The turbo's are the R32 GTR ones that have been profesionally stripped out, rebuilt with Steel wheels & internals to all N1 specs. So I guess they are New N1 turbo's. Car just has a 3'' from the turbo's, de-cat pipe and then 3.5'' to the back. HKS Pods. My power goal is 300rwkw, idealy 300-320rwkw but no more. That's enough for me on a street only car. Iv'e just gone out and bought all this brand new:
Apexi power FC & Hand controller
Apexi boost control kit
Nismo fuel pump
HKS Cam gears & HKS belt
**In the process of getting Nismo 600cc's or Sard 700cc's**
My main question is, will these parts with 16-19psi on my motor; get me 300rwkw or do I need to upgrade the AFM's aswell?? I was looking into buying the Nismo AFM's, but thats another $900. Am I better to keep that money or go out and buy them now. Keeping in mind my goal is 300-320rwkw and won't be looking for more power in the future. Ive already spent a heep on money on those other bits, just want to know if I need to get these AFM's aswell for my goal.
Much appreciate your input guys.
Cheers
You will not need afms's youll make 300 with the factory ones.
Save your money for later
+1.
OP, your rebuild N1 turbos will be old R32/33 tech, so they wont spool as well as R34 N1's.
I'd also swap out the decat for a 3.5in metal matrix cat. It will be far better for the environment, the colour/cleanliness of your rear bar, and your wallet if you get caught ;)
+1.
Yea I realize there just rebuilt R32 turbo's. Im not sure apart from rebuilding it with steel internals, if they high flowed or put other's housing's in it. I'll have to find out. But I think they did it all properly as they specialize in rebuilding and high flowing turbo's. But I can't afford a new set of turbo's and these should be fine for 300rwkw.
Yea the cat is a good idea too. Thanks
Well im glad I don't need to fork out more money for AFM's if my stock ones will flow 300rwkw. They have been cleaned aswell if that helps.
You must change the fuel pump.
It is cheap insurance really, everything else you keep talking about isn't required - but the fuel pump definitely is. It is just a ridiculous gamble for a $400 part.
If you find out it's now flowing enough 5 months later, when the engine pings and destroys itself - you'll wish you'd changed it.
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
