Motor Won't Come Away From Gearbox?
This one?? In other news: I cannot tell the difference between my red MX5 with the silver grey hard top......... and the Ferrari 599XX EVO, they might as well be twins, well.......apart from the big wang hanging off the back of the Ferrari...🤔🤣, without the wing they are identical
I think you'll find we're confused about what you were trying to do and how you were doing it. I would have thought that block rigidity was something you measured while loading the block in beam or in torsion, and that you would do so before and after grout filling, to see if putting material in there created a "composite" construction with the expected rigidity increase. Notwithstanding that the true function of grout is less about gross rigidity than local (ie preventing bore deflection/splitting and tying the bores to the main bearing locations a little better, etc etc). It is nearly impossible to follow your description of what you've done without closing ones eyes and making "aliens" hand shapes in front of oneself to try to follow the manipulations you've made. It's still unclear to me what you were trying to prove.
Not a fan of "racing stripes" really, I've seen a few done, with different styles of stripes, but no, not for me Although younger Mark probably would have thought differently about them
The correct answer is body colour. Admittedly it does look pretty handsome as-is in grey.
