2004 Ba Xr6 Turbo (Vic)
2004 BA XR6 Turbo Manual Sedan.
Up For sale is my 2004 Xr6 Turbo manual sedan I have owned it for 2 years and am the second owner. The car has been serviced regularly and has just had a major service. I have modified the car very lightly and have never had any problems with it besides a starter motor (that has just been replaced). I'm selling the car as I just purchased a house with my partner and would like to spend the repayment money elsewhere.
I have recently fitted 2 new tyres, a heavy duty starter motor, new brake pads and a brand new battery, I have also had the tinting replaced and a Ford factory towbar fitted (although I have never towed with it).
The car has been debadged at the rear with only the Ford logo remaining in the center of the boot (I have a set of original badges I purchased from Ford that will be included with the car if you wish to put them back on).
The car will be sold with a RWC and the remaining rego approx 10months, I will also have the car professionally detailed before it is picked up. I also have a spare turbo manifold that came with the new turbo that will be included.
PLEASE NOTE: The car is under finance and I will require payment to clear before I can hand over the keys.
Modifications:
* X-Force Twin Tip Exhaust (cat back)
* K&N Flat Panel filter and modified air box
* BA Series II Typhoon turbo (with the larger wastgate)
* Walbro 255lt Fuel Pump
* Exedy Heavy Duty Clutch
* Lightened Flywheel
* Lowered springs and aftermarket struts
* 19" G-Max wheels (some gutter rash)
* DBA slotted and cross-drilled rotors (front only)
* Polk Momo Speakers connected to the stock headunit (I also have all the wiring fitted and a amp in the boot all you require is a headunit, there is currently a headunit fitted to the car however it is not the best and isn't secured correctly I will take it out before sale or leave it in whatever suits the buyer it is included with the car either way.).
The only two negatves with the car are a slight shopping trolley dent in the front drivers door (barely noticeable) and some slight damage to the front bar which is underneath and also not very noticeable.
I will put some more photos up shortly.
Car is located in Ferntree Gully Vic.
Please call Andrew on 0406004135 if you have any questions or would like to view the car.
Feel free to call or message if you want to mae an offer needs to be sold ASAP
For those that asked via pm it was dynod at 223kW atw and is running the police tune (my brother is a mechanic at Ford so he flashed/updated the computer for me). Also the typhoon turbo came off a car that had done 40000km I have put roughly another 10000km on it since then.
Took it to the mechanics for a service yesterday and to see what it would need for roadworthy. Now has new plugs and oil. For a rwc it needs wipers replaced, new parkers cos it has red ones fitted, a number plate globe replaced and that's it.. ill get it all done before it's sold..it also now has a cracked front fog light lense (I'm just waiting till next pay so I can order a replacement). Also comes with 2 amps and an extra stocky wheel (so 2 including the spare). Also I have all the stock speakers if the buyer wants them.
NOW ACCEPTING OFFERS AS I NEED IT GONE MY HOUSE HAS ALMOST FINISHED BEING BUILT AND I'VE FOUND A NEW DAILY I WISH TO BUY.
 Share
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
