what have you fellow r33/r34 GTST/GTT owners out there installed to adjust or fix camber on the front of your cars?
i've read that the adjustible arms (from just jap) can be a pain to adjust whilst on car. can anyone confirm this?
the superpro kit will require the stock arms to be removed, old bushes removed and new joints pressed in = more time the car is off the road.
pros & cons of each kit and any personal experience with either in regards to installion, adjustment, etc.
cheers
https://www.sau.com.au/forums/topic/388112-r33r34-front-camber/
What you're saying is pretty accurate - The design is such that they are hard to adjust on car with the JJR arms and the superpro bushes will require you to press out/in as required.
If you want adjustable camber, you'll need to make a choice: re the above lol.
I've got the JJ ones.
Cost me $55 at JAX in Liverpool each time I do my wheel alignment before track days I get 3.5 front and 2.5 rear, then returned to street setting after.
They need to remove my front wheels and get it up on a hoist to adjust the front, all up takes them about 45 minutes max, nothing about bushes, a couple of big spanners is all that is needed.
I'm wanting adjustable castor arms ? now.
The bushes will be cheaper so if you are only chasing a degree or so adjustment for a street car they would be fine.
Myself, I'd get the arms for maximum adjustability.
ive been wondering this for a little while, was leaning more towards the adjustable arms but my question is whether there is much of a difference or benefit between the rubber bushes on the arms or pillowballs?? any help appreciated :)
Ive had my wheel aligments done about 15 to 20 times there over the last 3-4 yrs, LOL.
Ive had no problems with them, just be sure to tell them what you want it for, a couple of guys there do drifting and some trackdays, the boss owns a Rambler Gremlin drag car.
Go have a chat to them.
thanks for the info guys,
definitely made up my mind and getting the adjustible arms now.
Mark/MLR, do they do good work @ jax??
I put the Superpro ones in man, my mate showed me the tricks to fitting them and the second side i did in the car without any drama.... Hammer to knock the old bush out, a couple of accurate love taps and they fall out and then when fitting the new ones in i just used a monster set of multi grips and squeezed them in, was pretty easy to fit.... As for adjustment, i reckon its going to be harder but it all depends on the competence of the tyre guys you use i guess......
OR i could just leave them adjusted where they are at MAX neg camber :nyaanyaa:
i believe they only provide -/+ 0.05 degrees camber which is sfa lol
might as well pay bit more and get heaps more adjustment in the adjustible arms.
You;re doing something wrong if you're only getting that much adjustment! :laugh:
