I'm confused,it's the valve stem caps (dust caps) your talking about right?
If it is then yes,it is very common for them to get stolen by young thugs.I know you can get anti-theft ones of Ebay,to find them I just typed in "Nismo anti theft".
Saw an old mazda at traffic lights last week, he had a cable tie around one of the spokes on his hubcap and then thru the wheel . . . might not be able to do it with a 34 but maybe food for thought
Thats the problem, they wern't stolen at home and the only other place I parked it was at Carousel shops near the front door, and in the staff parking at Curtin, both places in clear view of security/people.
You'd firstly have to know they're worth something, how to take em off and have balls to do it in a public area. I'd gonna be suss on any GTR cap sales over the next week.
scumbags are getting more brazen every day (read stolen R34 sedan car thread) . . . your caps are probably "trophys" on someones wall by now
Edited by StevenCJR31
GTR badges have been known to go walkabouts also, usually end up on some losers toolbox or bookshelf. That said I have seen one on a Honda CR-V!
Yeah.. I've seen a 34 GTR badge on a guys toolbox at a workshop I used to do some work in.. Wasn't too happy about that
yep some d#*k stole one of mine at garden city shops last year!
carousel in known for skyline badges to mysteriously disappear, especially at night! :domokun::spank:
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
    • If it's a factory 20de manual probably has the 6 bolt flywheel in which case the det clutches won't work as they're 9 bolt.
    • All RB push clutches are interchangeable. AFAIK, the 4cyl ones are not. Different flywheels. The RB small box is not identical to the 4cyl boxes. Just very similar.
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
