Having problems with my R34 gt, the engine management light comes on and off randomly. Was like that for a couple days and now the car has started to shutter, more so when stopped at a set of traffic lights.
Then it suddenly stops and its back to normal, sometimes with the engine management light on, sometimes not. The car only shudders every now and then.
Any help would be much appreciated as i'm clueless!
https://www.sau.com.au/forums/topic/388158-engine-management-light/
as above, the engine light is usually caused by failing coilpacks in a 34. a quick search will show you how to do a fault code check. my money is on it being coilpack related.
Yeah I've been looking around and most people have said coil packs. Will do a check on them, and see how it goes. Thanks!
Sounds like what happened to my R34.
How is your fuel economy and acceleration? If your acceleration is feeling sluggish and your getting worse fuel economy than normal then its definetely a misfire in one of your coilpacks.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
