  • Replies 46
Hi mate,
Evo 8 block is a better base to work on than Evo 7 if we are chasing big power.
It's because the 8 has upgraded rods than 6.5 and 7.
Just let me know if you're keen to buy the car, few guys are trying to gather up some cash to get the car.
But no one has full cash ready to go as yet.
Cheers
Hi mate,
Cheers
so engine hasnt been cracked open...?
and how many kms has the evo 8 engine done and car done...?
What are you planing to buy??
A small car that I can share with the mrs.
Maybe SLK, Z4, Boxster, Cayman.
Will be much slower than the evo, but at least I keep her happy
Of course, the WHOLE bottom block is replaced with EVO8 block, which has done about 60k kms.
I use all brand new parts (headgasket, head studs, etc) so it's a much better build than factory. Nice and fresh ready for big power.
The top end has also been modified, 272 BC cams, camgears, etc.
The car itself has done 78k in total.
When I build cars, I build it seriously, no point saving out a little money if it will cause trouble in the future.
Regards
Gerald.
Regards
Gerald.
Well said mate.. If only you wanted an sti.. I would swap instantly haha.. GL with the sale mate..
Hey there,
Just curious but what sort of power is this thing putting out? I've been in mildly modified Evo's before and they were fast enough. I can't imagine what sort of acceleration this thing has.
Either way, nice car. I'll send a link to a mate of mine who loves Evo's and has too much cash from working the mines.
Hey there,
Thanks mate.
It's putting 240awkw on 98 pump fuel, which is a lot for an evo.
Response is great, more than what I need.
Thanks again for passing the link.
I hope it goes to a good home, so many offers but people just have no cash to buy it.
Nice Car...... It is exactly what i need for whizzing around the hills..... How many kw at the wheels?? and what boost is the current tune on?
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
