Hey guys,
I just wanted to ask a quick question about the R32s security system. hopefully one of you guys might be able to offer some advice.
My R32 when I bought it came with two things, my standard key and a remote keyless entry module (with the lock,unlock,alarm and silent buttons). Now the module used to sit on a keyring but since its plastic the outside clip broke and now I have to physically carry both my key and alarm wih me (and I know im going to loose the module eventuallt).
Does anyone know any companies who can make custom keys that combine the key itself along with the lock and unlockvbuttons from the remote keyless entry module? Much like the way most modern cars have them inbuilt into one large key.
It would be great if anyone knows a company or place who can integrate them.
Thanka guys!
https://www.sau.com.au/forums/topic/388182-questions-about-r32-security-system/
CA model glue and a dremel your all set..haha sorry thats the redneck solution
you can setup a alam that is completely keyless, entry and starting but most installers wouldnt have a clue how to do that , only the best ones know how and it will cost a bucket load to do , or even with your iphone, andriod in your pocket now
your kinda vague, if you mean the key with the lock unlock buttons ? or a true alarm system ? sounds to me like a rubbish model that would be best replaced anyway and just use a normal key
those factory keyed/less system you talk of, cost a butt load to fix when the key fails, in a year or a day . hundreds to thousands of dollars depending on the car model. bentley comes to mind right off the bat, with a bad key issue.
hmmmm in sydney I would say chris rogers might know if someone with such skills , I know some shops but cant vouch for the skill set first hand. sorry
take a photo of hte remote. I dare say its a dealer upgrade.
Hey guys thanks for the info. I have attached a pic of both my key and my keyless entry unit. im sure the keyless entry unit is not genuine as I was under the impression no R32 came stock with an alarm system / keyless entry.
basically the unit just has unlock,lock,alarm test and alarm mute, besides supergluing them together, which while tempting is pretty bodgy. i dont really want to spend a fortune as the system still works, be great for any more input thanks guys!
Good to know its just some random security alarm.
Would you know roughly how much a nes security system may cost? Mine has the keyless entry / remote locking, door sensors and boot sensor and window sensors (as in if you try to put your arm inside when the w
indow is down the alarm sounds)would be great to get it all replaced :-)
thanks for the input guys!
best to look around sydney for a decent installer. forget shopping on price. hit up danielr34 on here (security in motion) as he's in sydney - I'm not.
Awesome mate thanks for the info / help!
    • As a general rule removing rubber fuel hose is so difficult I would replace it if it hasn't been done in the last 5 years. The risk you damage the liner or one of the inner layers is pretty high if it's not almost brand new. BMW's recommendations around coolant hoses is similar. My R33's fuel hoses at the fuel tank were so perished that they were ready to burst FYI.
    • Ah yep, will do. Cheers!
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
