i just want to clear this up, i got accused tongiht of my car being a rice burner, but its a s13 turbo, but i wanted to know wat is rice? and wats is a rice burner?
I think rice is just stickers n stuff, but is a rice burner someon that burns rice or someone who has a excel with flames down the side?
https://www.sau.com.au/forums/topic/38820-rice-and-rice-burners/
  • Replies 40
You'll find that living in Australia, many Aussies call any Japanese car a "rice burner". Doesn't matter if it is stickered up or turbo'd, the fact that it was produced in Japan is enough to warrant it being called a "rice burner". This isn't a new thing, they were even doing it when my dad was at Uni.
"Rice" is generally considered to be anything that alludes to the car being quick, when it clearly is not. Ie. phat exhausts on a N/A car, fake intercoolers etc etc
Wow, is that truely your first encounter of being labled under the "ricey" banner???
get use to it!!! lol
I work 4 Holden - U can imagine the sh*t that I cop. I've got alot of friends with some very fast good ol' V8's - we always dissin' each others cars - all in good fun. theres soooooooooooo many comebacks for both groups of cars.
The rivalry has been there for years - & will always be there. makes things interesting
yeah Rice can be labelled as uneccssary mods that dont help performance ...... just look at uneekwahns car *stir, stir* :D
or Rice burner just a jap import car.
I called my friends Sigma rice once (he was trying to do it up) and he came back with "If mine Rice then you have an Industrial Sized Rice Burner" .... he made a good point i shut up LOL or you could have Holden parents like mine who go "Whats the jap crap doing under our driveway"
i liked it when i got my car, couple of mates go 'ahhh rice boy'
i was like - whats rice about my GTR
the GTR wheels?
the GTR body kit?
the GTR badges?
its pretty much stock - so it can't be rice, that shut them up
jus jelous trevs, therl always b 1, i wuld rathr b a jap car ownr than a vb swign, winnie blu smokn, aca daca listn fully sik subwoofr stok commondor drivn TREV!!! giv it up boys youl neva beat us :)
RICE 4EVA!!!!!!
:confused: Engrish??? :confused:
I think Jimih has hit the nail on the head here. Ive read many threads in the past about rice and i would say that was the best explaination ive heard yet.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
