  • Replies 40
There is also a kind of scorn reserved for those who do the twin system exhausts etc. to stock holden sixes and other non-asian made cars. It is the same illness that effects the 'rice boy'. The strange desire to put a hornet bonnet scoop (not ducted to the underbonnet) on a 4cyl torana is the very same sickness. It all comes down to the owners firm belief that deep down his/her car is faster for the effort.
Beware of playing the same game as the 'trev'. Don't be drawn into a counter culture that likes the 'cheap wine only comes in 5L' stickers. Instead appreciate 'all' performance. It is a truely sad day when the 5L V8 powered whatever kicks your arse whislt you have one of those stickers and believe me there are a few around that WILL kick your arse.
well my mate in his "HYPER' excel twin "PHAT" exhaust, lowered n mags (also spoiler thats bigger than the actual car)
said he was a rice burner, cos he burns on lancers......
2 months later he wrote off his car, slaming into a pole, he said the car was to fast and powerful for him, and wen he said he tried to "drift" around a corner, his back flipped out and lost control.....
i just smilled and said, yer i no....there hell fast aye mate, did u have a kappa sticker on it?
Cool thanks dude, do you know if a knock sensor can be installed on a rotary?
short answer: no. I don't know
long answer: my understanding is that the "knock sensor function" of some bolt on electronics or even the plug and play stuff is that the knock sensor is actually pre-existing and that these just take an electrical feed.
In the R33s, the nock sensor is used by the computer to retard the timing in the event of detonation.
Therefore, my advice would be to check the wiring diagram on the car. It will probably have a knock sensor already.
if not, then you need to ask someone who knows what theyre talking about - probably in a thread related to what you're asking about.
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
