Hi all,
Clearing the garage of whats left, list as follows-
1) Side skirts and rear pods - $200 ono
2) R33 standard rims and tyres good condition - $200 ono
3) R33 twin piston rear calipers - $130 ono
4) R33 gtst brake booster and master cyl - $100 ono
5) R33 standard airbox - $100 ono
6) R33 centre console - $50 ono
7) Pair of r33 2 door door trims - $80
8) Aftermarket dump pipe to cat suit r33 standard turbo, has cat in pipe - $100
9) HKS turbo timer - $40
10) Standard R33 grille in grey - $30
11) Instrument cluster surround - $20
12) Misc struts -
a)Standard front struts pedders springs, 1x strut leaking - $40
b)Standard front struts HKS springs good condition - $60
c)Standard rear struts unknown brand lowered springs good condition with matched pair of front springs - $50
Many more parts available mainly interior trims etc feel free to pm or Email me
List of whats left as follows-
Z32 ECU with nistune board set up for RB25 running tune to suit stock turbo 11psi exhaust and pod.
$550 ono
Steering column complete with barrel and key $20
Airbag steering wheel fair condition has unused airbag unit $20
Front pedders x2 and HKS x2 springs $35 pair
Boost control solenoid std $5
Misc interior lights etc $5 ea
Skirts $100 pods $70 or both for $150
R33 stockies set of 4 $180
Brake booster and master cyl $60
Stock airbox $80
Centre console $40
Door trims $35 each or both for $60
Rear interior quarter window trims $15 ea
  • Replies 64
Posted Images
