Needing more power from a VQ25DD Di. I posted it in this section because it's NA and I would like fresh opinions and ideas rather than everyone in the V-series section telling me to wait and get a VQ25DET or VQ35DE
I'm on my P's so nothin major
https://www.sau.com.au/forums/topic/388225-needing-more-power/
first performance mod should be a helmet, long shirt and long pants,
then go do some driver training
then go to the race track/ drag strip/ skid pan, do your best with what you got, when you "hit a wall" and cant improve, upgrade your suspension and brakes and tyres (track work isnt all about putting your foot down)
then go back to the track and try again, tune the suspension until it suits what you want it for
while you do all of this, plan and research what you want to do with it once your off your P's.
start buying parts for when your off your P's
anything other then that on your P's is not going to really improve anything, plus in nsw its 12 month suspension and 7 points for a P plater to drive with "prohibited mods" aka 15 months extra wait to modify your car when your off your P's
Need more power. lol. I learned to drive in an Austin A30 750cc and my first car was a KE30.
If you wanted performance mods frankly you bought the wrong car, there are very few parts available for the VQ25det let alone the dd. Best bet is to buy a half cut and slot the 3.5 in when you are off your P's.
you'd get more power from raising the compression ratio ( might cause detonation and ignition timing issues though so ask a performance shop about that) and getting the cams reground for higher lift, do a higher flowing cat and exhaust, cold air intake, if its a manual, put a lightened flywheel in maybe, and try to get the computer chipped or modded.. How will anyone know if you have high compression or a reground cam, its all internal..
there was a 300zx non turbo on here not long ago, it got down to 14sec quarters, search for what he did cause thats a quick P platers car..
didnt realise it was already 11;1, gees that really is a weak motor
Edited by SliverS2
VQ25DD - Leave it as is. Not much can be done to it. I think they have squeezed enough power out of it IMHO. It's already direct injection and high compression.
I'm suspecting your intake plenum is probably blocked up with lots of gunk from the EGR system (common issue with direct injection systems). I'd clean the plenum 1st, then get high flow air filter and a catback.
Damn straight. Shoulda seen the speed I could punt my 2L Datsun 1600 along at. It probably had a whopping 80hp at the wheels but pretty much nothing could stick to it once corners were introduced. TBH that car is still the most fun car I've ever driven. I'd give just about anything to have it back...
My opinion to the OP, leave it as is, spend as little as possible on it. Every dollar saved now is a dollar you can put towards something with potential once you are off your Ps.
i have found a few things here and there, but noting to write home about. according to wikipedia my car has 158kw (@motor) but if i could get that/close to that at the wheels ill be happy.
yeah tossing up between the following when i get my Blacks...if the world hasnt ended hahah
JDM U13 Bluebird SSS (SR20DET, AWD)
V36 350GT SP sedan
M35 Axis Autech Stagea
opinions?
you have 2 newer cars and 1 older car on that list. i would go the newer cars over the old bluebird. or go a silvia/180sx over the bluebird. they are better looking, lighter, and most likely the gearbox will be in better condition. if you want to go AWD sr20 then find a tidy example of a GTiR. or even just get a SSS pulsar with a turbo conversion done, or do it yourself.
You had it on a dyno yet to see how far you have to go?
i'd take a guess that he's 35 to 40kw short of what he wants, which is engine work realms of power gains.
Fast + P Plate legal cant be used in the same sentance.
Supposedly S2k's are supposed to be the quickest restricted vehicle and as good as they perform for a NA 4cyl they are horrendously slow even when compared to a mild turbocharged vehicle with an exhaust and abit of boost.
Save your cash bud.
Yeah that's my car, not a lot done mod wise just Exhaust, intake, underdrive pulley and a clutch. OP Learn to use the power that's there IMO, look at go fast mods when you can't go any faster on its current setup.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
