I found and run the test, but unfortunately did not show up anything, does anyone know where the water control valve is, i presume its an electric solenoid type hidden away somewhere??
Climate Control Diagnostics R32 and R33
The climate control has a diagnostic mode.
Enter the diagnostic mode by pressing the OFF button for five seconds within ten seconds of
turning the ignition on.
Sensor check
Sensor check is selected by pressing HOT switch (the red triangle) while in diagnostic mode.
The microcomputer detects whether each sensor input signal is within correct parameters. The
results are displayed on the screen.
If normal, a "20" is displayed.
If abnormal the failed sensor number is displayed. The sensor numbers are as follows:
20 - all is normal
21 - outside air sensor
22 - Inside air sensor
23 - Water temperature sensor
24 - Intake temperature sensor
25 - Sunload sensor (small sensor on the left hand side of the dashboard near the windscreen)
26 - PBR
27 - Refrigerant temperature sensor
This should tell you if any of your sensors are faulty.
Mode door position check
(This is probably not the cause of your problems but it is a nifty self check to play with).
While in Sensor check, depress the HOT button again. This will operate the the mode door
actuator, and checks the whether the position detection switch is operating. Again the results
are displayed on the display.
If normal, a "30" is displayed.
If abnormal the number of the faulty mode is displayed as follows:
30: Normal
31: VENT
32: B/L (Bi level)
34: FOOT
35: DEFROST/FOOT
36: DEFROST
https://www.sau.com.au/forums/topic/3883-no-heat/#findComment-62873
Originally posted by inark
its 1am... but im going outside to have a fiddle with it just cause that looks like fun haha
lol yea i like fiddling at 1 am too...
sorry i cant help u there jethead. i did the test and 25 - Sunload sensor seems to be faulty....bo my question is, what does it do, and is it important???
https://www.sau.com.au/forums/topic/3883-no-heat/#findComment-62925
You should have got error 25 (Sunload Sensor).
Word of caution, even in shade on a bright sunnny day you can get error 25.
https://www.sau.com.au/forums/topic/3883-no-heat/#findComment-63194
Originally posted by skyline33
leon,
I thought you fixed it
errr the guy that sold it 2 me did....but then a few dayz ago it made that sound again.... :) I don't wanna go back 2 him and get it fixed again..u said u know someone that can fix those stuff right? Need some help man
https://www.sau.com.au/forums/topic/3883-no-heat/#findComment-63498
yer..it was the gate thingy that heat your windowz when it goez foggy....it wasn't moving properly.....it still workz though, just makez that annoying sound..... And I dunno y but I get hot feet instead of cold feet...heater is on no matter I turn it off :) weird shit....
https://www.sau.com.au/forums/topic/3883-no-heat/#findComment-63503
On the righthand side of the gearbox tunnel Adjacent to your left foot is an servo/motor mechanism that sequences the buterflies and water valve via a push/pull cable. This mechanism was stuck, gave a bit of a helping hand and away it went, all is fine now. Fault code 26 then dissapeared, left with Sunload sensor fail but who cares...Ive got heat now..
Can someone tell how to identify/find the Sunload sensor????
https://www.sau.com.au/forums/topic/3883-no-heat/#findComment-63513
    • It's because the air comes in over #3 & #4. The two "dead" ends of the plenum are at #6 & #1, with #6 being a little more "compromised" (Sorry about all the quote marks) than #1, due to the shape. So you get the dead end effect at #6 & #1 where dynamic pressure converts to static pressure, likely causing the air flow to be highest for these. The others are then just working in from the ends to the centre. 6 -> 1 is only valid for FFPs.
    • Cut back on the attitude champ, no one is obligated to help you. The chances of Forester owners on here are quite low, considering this forum is called Skylines Australia. https://www.subarupartsdeal.com/parts/subaru-under-cover-front~56410sa000.html ^ that picture looks wrong, because if you see the diagram, 56410SA070 looks correct. You can always check where the mounting holes are on your car, and compare them to the pictures.
    • Hey Duncan, I've always set them up from 6 -> 1. Due to slightly higher EGT's, I also add a small amount of fuel to cylinder 6 & 5. I understand why you start at 6 but curious as to why you then continue somewhat based on firing order? Thanks
    • United E85 is always 85% ethanol. At least it claims to be. But that goes out of the window about thirty seconds after you put a tank of it into your car and can't do the math to determine if you have 76% ethanol, or 47% ethanol or 26% ethanol because you put 33L in, then 16L in, then a full tank of 98, then "Some" E85. Ethanol tunes that aren't full flex or full E85 all the time are just absolutely a waste of time. Don't be stupid and ruin your car.
    • I don’t mean this in any negative way. But, if u are after this type of data why don’t u have a flex fuel sensor?
