I thought all the automatic r33s got 4 speed gear box, but when I listen to my car, its voice drops 4 times after it lauches, I mean I can hear it changing gears four times after when it accelerates from the 1st gear, which means there should be 5 gears in it!! Is there really any 5 speed automatic gear box exist for r33? or my gear box is just wierd? or it changes 4 times just mean it's 4 speed?...
Can any expert give an answer...
there is a 5 speed auto option. however the 4 speed runs a lock up torque converter which will make it sound like it is changing gears 4 times. my 4sp auto VT commodore does it. the torque converter will lock in in 3rd gear, which sounds like a 3rd gear change and then it will change into 4th
AFAIK there was a 5 speed auto available on NA R33s, . . but not many, the code for the auto/engine/rear axle assembly will be on the factory plate on the firewall . . .take a look
Sounds like the lock-up to me. Same thing with my 32 gts-t. 1st, 2nd, 3rd, overdrive, Lock-up. You'll note the lock-up only moves the revs down slightly, also once it is engaged it drives like a manual so when you load it up the revs don't immediately change. You can tell the 4th change is overdrive by turning it off, that will also stop the lock-up.
R33 2.5 na had the option for a 5 speed auto.
Only on the Type S, Easiest thing to do, jump into the VINS you want fasted thread and it will tell you if you have a 4sp or a 5sp.
http://www.skylinesaustralia.com/forums/topic/128496-vins-you-want-fasted/page__pid__6191910__st__2980#entry6191910
Edited by Miguelone
or just look on the japanese blue compliance plate on the firewall! if its a 5 speed it will read something like RE5R01A or RE4R01A if 4 speed auto . . .easy sorted
my cars an auto, and the compliance plate reads re5r01A? so does that mean I've got a five speed auto box, and does it mean mines a type s?
yes . . . its a 5 speed, as for it being a type S . . NFI
there is a thread regarding type s 33s on here just search for it, if your car is a type s the model number will read E-ECR33 insteadof ER33 (I think) just search for it.
also type s has, LSD, rear sway bar, 5 speed,and rear wiper factory AFAIK
There's a few different variants from what I've found. For instance mine had turbo brakes, rear wiper, 4speed and no rear swaybar and is an er33 but in fast comes up as GTS25/S
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
