As per the title I have 4 R34 GTT rims with Toyo R888 semi slicks.
The rims have painted black. They are straight and the only damage is some paint chipped off from the socket changing them and the tyres being fitted.
Toyos are R888 GG 225/45/ 7R 17 94W.
The tyres have done 6 tracks days. Two of them are probably at 40% so would get a few more track days. The other two have flat spots but have the same amount of grip as the other tyres. I was running them on the back wheels OK but really they are only good for skidders.
Looking for $550 ono.
I am in Bayside of Brisbane.
Can freight at owners expence. I think with E-Go it should only be $100-$150 going off other peoples threads.
https://www.sau.com.au/forums/topic/388332-r34-gtt-rims-with-r888/
    • Gotcha, I mean that is at least good to hear. Are there signs, or troubleshooting tips to make sure the transmission is operating properly?
    • Well thats probably not gonna happen right away. LOL
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
