Okay, ive searched and found different answers, and youtube video's shows different too
can someone with tomei cams the 256degree 8.5lift tell me what they are like, im talking idle and just general upto 3000rpm driving, is it a pig that idles crap??
so far i see they are good after 4000rpm , but i just need to know that the off boost low rev driving isnt really bad, cause thats where most of my driving is..
FYI, this will be for a gtx3076 , 18psi , external gate blah blah blah...
https://www.sau.com.au/forums/topic/388337-tomei-cams-on-a-r33-gtst/
they idle almost like stock. youll be fine
ive got a very similar set up
what do you think to this utube segment?
is that close to the idle? i know its 270degrees 8.5lift
ive enjoyed reading your thread, sounds like an awesome result , i hope it makes you shake at the knees a bit, thats what im after with mine, 300rwkw with an adrenaline rush, respect!!
Edited by SliverS2
Yeah there pretty similar sound to stock maybe a tad bit more rough and sound abit more like a rb26 up higher revs more deeper note. They are fine to drive off boost it wont feel like a pig but yeah main gains will be through midrange and a little bit up top.
ah cool, thanks for that reply, i dont mind a tad rough idle, just wanted to make sure it would have mostly normal response off boost, my decision is almost made now,
do you think it needs cam gears as well , its says on website that is already pre dialled, should i buy cam gear as well ? and if so , just exhaust or intake too?
any advice is appreciated.
cheers
Well definately dont need intake camgear as your retaining vct, I put an exhuast cam gear on mine but my tuner found it made gains on the stock setting so didnt end up changing the position so I didnt end up needing it.
From what I have heard very little change to idle, very little loss of low down power but a lot more midrange and some more top end. Most results I have seen are around ~20rwkw peak power but more in the midrange.
How much does it cost to get someone to fit them?
sounds like a win win modification then, im keen to fit them myself , just have to find some DIY articles and maybe a gregories manual ,
cant be too much different to fitting a normal cam on an RB30?
There not that hard to install pretty easy providing your confortable with doing a timing belt you should have no problem. Just follow the workshop manual it has a pretty good step by step only thing I would recoment you do is rotate the crank a few degress backwards from TDC when removing and installing cams then align cam gears followed by crank also would be a good idea to upgrade the valve springs and replace valve seals if your changing cams.
thanks ill do that, dont really want to take the head off to do springs and seals though, sounds like a big job
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
