Hi guys,
I just bought a big PWR radiator and twin 11" Spal fans for my FJ20 bluebird. The engine started making a lot more heat than the old radiator could handle since i built the engine. Anyway the PWR rad has certainly done it's job and is now bringing the temp back down, even at idle when the thermos are running. On the highway it runs around 75-78 deg, around town it runs between 77 and 82 and thrashing it normally sees no higher than 82 either.
Last night i was sitting in the heaviest traffic since i put the radiator in and it was stop start traffic for quite a long time. The temp sat between 83 and 84 for around 10-15 mins, but the thermos couldn't seem to bring it down any lower. Inlet air temps were coming up to 50 degrees as well, so i can only guess that the whole system became heat soaked and it couldn't move the hot air.
My question is,
1) How can i reduce some of the heat soak? - would things like a turbo beanie help?
2) Who else sees similar characteristics? (i realise 84 deg is still cool but i'm curious)
Thanks in advance,
Gareth
https://www.sau.com.au/forums/topic/388361-heat-soak-and-running-temps/
Just be a case of the fans have found their limit in terms of airflow and cooling.
Driving around you were no doubt getting aid from the actual speed of the car + fans, rather than the fans outright which in stop/start has lead to it picking up. If you had 5mins of moving (80km/h+) it would've come back down.
If you have heat shielding deflecting the heat, of course that will help - however I'd see it as almost inevitable that it will heat up to those types of temps. Ambient air temp also plays a factor, was it warmer than normal perhaps?
Also if there are larger fans/CFM, this might also help. Perhaps water spray for the I/C as well to get temps down.
Still as you said, 84 is still low and it's really not much of a drama.
What temp does your thermostat open? The skyline ones are high 70s (79?), so 84 would be a perfectly normal running temp. Remember, the motor needs to be warm as per nissan's design to work efficiently (particularly fuel)
I wouldn't worry about the temps until they head past 100 under heavy use.
Hey guys,
the thermostat is 77 deg, and from running it with the cap of the rad, it seems as though the thermostat is fully open and water running flat out by 82.
It was a warm evening and then i drove around an underground carpark so i think it was pretty good really, i was just interested to see the effect heat soak had and if you guys have the same sort of characteristics. As soon as i got moving, the temp came straight down again.
As for the PWR rad. Its fantastic. worth every bit. The rad is no bigger, but it runs PWRs close mesh core now and 2 top quality SPAL thermos that cover the whole radiator. Before, once the thermos came on, even on normal road cruising, they couldn't bring the temp down and going up a big hill, it would just climb, as it would with stop start traffic. Now, the hottest i've seen it was 84 the other night in traffic.
Obviously i want it to be able to pull the temp back down no matter what, even at idle, so im curious to know how other cars (especially with big cams and lots of stuff to make them hot) react in heat soak conditions.
Has anyone else had the same heat soak effects and what can help? (R31 nismoid, water spray on the cooler i know works well from having it on the dyno)
Cheers for the input,
G
I dont have too much trouble with temperatures, but i noticed mine goes up several degrees when the a/c gets turnt on, has gone up to 87 and thats cruising on the highway,
apparently the underbody cover, is that what you call it? aids in cooling the underbonnet temps, thats what i was told and for the heat soak you can put the air filter in the front bumper down infront of the wheel, thats what im having done with mine.:thumbsup: plus some ceramic coating on the turbine housing etc
well naturally the temp is goin to go up a little bit as the A/C condensor sits right in front of the radiator
the radiator is now getting hotter second hand air flowing through it
i imagine that would effect the temp a few degress
that and you are loading up the engine with an extra auxillery component
Edited by GTR_JOEY
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
    • It sounds farrrrrrr too cold at your place Duncan... Here I was thinking our 10 degrees overnight is getting cold...
    • oh yeah, reminded this morning....bin lids frozen shut too
    • In my case not, because of total reno. But yeah.
    • Did you use an electronic speedo drive? Does you speedometer read all the way to 180km?
