Hi guys,
I just bought a big PWR radiator and twin 11" Spal fans for my FJ20 bluebird. The engine started making a lot more heat than the old radiator could handle since i built the engine. Anyway the PWR rad has certainly done it's job and is now bringing the temp back down, even at idle when the thermos are running. On the highway it runs around 75-78 deg, around town it runs between 77 and 82 and thrashing it normally sees no higher than 82 either.
Last night i was sitting in the heaviest traffic since i put the radiator in and it was stop start traffic for quite a long time. The temp sat between 83 and 84 for around 10-15 mins, but the thermos couldn't seem to bring it down any lower. Inlet air temps were coming up to 50 degrees as well, so i can only guess that the whole system became heat soaked and it couldn't move the hot air.
My question is,
1) How can i reduce some of the heat soak? - would things like a turbo beanie help?
2) Who else sees similar characteristics? (i realise 84 deg is still cool but i'm curious)
Thanks in advance,
Gareth
https://www.sau.com.au/forums/topic/388361-heat-soak-and-running-temps/
Just be a case of the fans have found their limit in terms of airflow and cooling.
Driving around you were no doubt getting aid from the actual speed of the car + fans, rather than the fans outright which in stop/start has lead to it picking up. If you had 5mins of moving (80km/h+) it would've come back down.
If you have heat shielding deflecting the heat, of course that will help - however I'd see it as almost inevitable that it will heat up to those types of temps. Ambient air temp also plays a factor, was it warmer than normal perhaps?
Also if there are larger fans/CFM, this might also help. Perhaps water spray for the I/C as well to get temps down.
Still as you said, 84 is still low and it's really not much of a drama.
What temp does your thermostat open? The skyline ones are high 70s (79?), so 84 would be a perfectly normal running temp. Remember, the motor needs to be warm as per nissan's design to work efficiently (particularly fuel)
I wouldn't worry about the temps until they head past 100 under heavy use.
Hey guys,
the thermostat is 77 deg, and from running it with the cap of the rad, it seems as though the thermostat is fully open and water running flat out by 82.
It was a warm evening and then i drove around an underground carpark so i think it was pretty good really, i was just interested to see the effect heat soak had and if you guys have the same sort of characteristics. As soon as i got moving, the temp came straight down again.
As for the PWR rad. Its fantastic. worth every bit. The rad is no bigger, but it runs PWRs close mesh core now and 2 top quality SPAL thermos that cover the whole radiator. Before, once the thermos came on, even on normal road cruising, they couldn't bring the temp down and going up a big hill, it would just climb, as it would with stop start traffic. Now, the hottest i've seen it was 84 the other night in traffic.
Obviously i want it to be able to pull the temp back down no matter what, even at idle, so im curious to know how other cars (especially with big cams and lots of stuff to make them hot) react in heat soak conditions.
Has anyone else had the same heat soak effects and what can help? (R31 nismoid, water spray on the cooler i know works well from having it on the dyno)
Cheers for the input,
G
I dont have too much trouble with temperatures, but i noticed mine goes up several degrees when the a/c gets turnt on, has gone up to 87 and thats cruising on the highway,
apparently the underbody cover, is that what you call it? aids in cooling the underbonnet temps, thats what i was told and for the heat soak you can put the air filter in the front bumper down infront of the wheel, thats what im having done with mine.:thumbsup: plus some ceramic coating on the turbine housing etc
well naturally the temp is goin to go up a little bit as the A/C condensor sits right in front of the radiator
the radiator is now getting hotter second hand air flowing through it
i imagine that would effect the temp a few degress
that and you are loading up the engine with an extra auxillery component
Edited by GTR_JOEY
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (掳C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
