Hey all
Have decided to put my Red R33 GTR up for sale. Time to upgrade to new GTR and funds would come in handy.
Here is a bit of history on the car, Was purchased dead stock in Japan in 1998 ( yes thats correct car was only 1 year old when imported ! ) and was complied in 1998 for an elderly man who owned multiple McDonald stores here in Adelaide. 6 years later the next owner purchased it and rarely drove the car. In the next 5 years a lousy 15,000 km were clocked up.
At time of import it was a grade 5 and is still in near perfect condition all these years later.
The color AR1 is rare and i have not seen to many in this that are the real deal ( have seen a couple sprey jobs but not factory AR1 ).
It is a great looking color especially in direct sunlight.
This GTR needs to be seen to be appreciated, It is extremely clean and wont disapoint. Only bad thing with the interior is a small 2cm slit in drivers seat from my keys but can have that fixed when deposit is paid.
Now for the important stuff!
VEHICLE:
RARE 1997 NISSAN GTR V-SPEC SERIES II. 84xxx KM
BODY:
RARE STOCK FACTORY AR1 ( KNOWN AS NISMO RED FACTORY COLOR ) RED V –SPEC.
PREMIUM WINDOW TINT
ENGINE:
RB26DETT ENGINE.
APEXI POWER FC WITH HAND CONTROLLER
TRUST (GREDDY) T517Z TWIN TURBOS ( 300kw @ 1.1 BAR )
PORTED EXHAUST MANIFOLDS
APEXI PODS
R34 GTR AIR FLOW METERS.
GREDDY OIL FILTER RE-LOCATION KIT.
GREDDY INLET & EXHAUST ADJUSTABLE CAMSHAFT PULLEYS.
GREDDY TIMING BELT, ALL TENSIONER BEARINGS REPLACED.
EXESS MOTORSPORT ENGINE GROUNDING KIT.
EXHAUST:
TRUST TWIN FRONT PIPES.
3.5” HIGH-FLOW CAT.
TRUST POWER EXTREME II 80mm EXHAUST.
CLUTCH:
BRAND NEW OS-GIKEN HEAVY DUTY TWIN PLATE & FLYWHEEL FULL KIT
FUEL SYSTEM:
BOSCH 040 IN-TANK PUMP.
ALL INJECTORS JUST SERVICED.
BRAKES:
BREMBO FRONT & REAR.
NEW ENDLESS SS BRAKE PADS ALL ROUND.
SUSPENSION:
NEAR NEW HSD FRONT AND REAR COIL OVERS.
FRONT & REAR CAMBER KITS.
REAR ADJUSTABLE TEIN PANHARD RODS.
BATTERY:
OPTIMA D31 EXTRA H/DUTY GELL-CELL.
WHEELS & TYRES
STANDARD R33 GTR WHEELS.
AUDIO GEAR:
ALPINE CD TUNER.
ALPINE TYPE S 12” SUB IN ALPINE BOX
MASSIVE (USA) 6” SPLITS FRONT
MASSIVE 2-WAY 6.5” SPEAKERS @ REAR.
SECURITY :
CHEETAH PRO-STOPPER TOP-OF-THE-LINE ALARM SYSTEM WITH TRIPLE ENGINE IMMOBILISER & REMOTE BOOT RELEASE.
SERVICE
SERVICED EVERY 5000KM USING ONLY THE BEST FILTERS AND OILS.
CONTACT : PM ME
PRICE : $28,000.00 ONO
PICTURES : WILL GET THEM UP TONIGHT
https://www.sau.com.au/forums/topic/388381-rare-ar1-nismo-red-r33-gtr-for-sale/
PICTURES
Slightly dirty but will have full clean and polish for new owner when time comes.
Excuse the phone images but digital camera was dead.
also excuse the couple bugs on front bar, couldnt help myself to a quick drive today ha ha ha
Can get more if required.
Edited by stylz7
AR1 red is rare, from what i have been told / seen, AR1 was only produced from May - June 97 and not many were made in this color.
There are a few Maroon ones but not many AR1 Factory ( NISMO RED ) colored ones.
Cheers
Edited by stylz7
The color does set it apart from other GTR's, Also car comes with 6 months rego and water pump was replaced with N1 water pump when timing belt was done.
Happy for any viewings or tests if needed.
  • 1 month later...
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
