Hi all,
I've had my car for a few months now and there are some things which i can easily see were modified. However, I'm still not sure whether my turbo is stock or not.
It already had a manual boost controller installed and it was turned up to max boost, which boosts beyond the reaches of the stock boost gauge. I'm worried that if it's a stock turbo, the turbo can't handle the boost and will blow soon. I don't want to turn down the boost (for obvious power reasons). Are there any tell-tale signs of a stock turbo? I can't see any signs or writing on the turbo without taking it out. It seems to be a bit rusted compared to the rest of the components next to it so I'm wondering if that's normal, or some second hand or aftermarket turbo in there.
I'll put some pics up when i get a chance.
Thanks guys,
Jay-C
https://www.sau.com.au/forums/topic/388400-is-my-turbo-stock/
Put it on a dyno and find out just how much power its making and how much boost its running.
Dyno opperator will be able to tell you if its safe or not.
If its got well over 200kw and tuner says its safe you can assume that its tuned and has an upgraded turbo, if its making around the 200 mark or less then its a stock turbo and you should turn the boost back to 12 at most.
This is if you fail at identifying what it is for yourself. You really should have asked about the cars full history when you handed over your hard earned coin....
Not sure if this helps you at all, but these are pics from the original owner of my car when the old turbo was done -
BEFORE -
AFTER -
Errrr it would appear the first AFTER image is EPIC FAIL..... Sorry >_<
Just going on the pictures, you can quite clearly see that the turbine side (exhaust wheel) is much larger and looks to be steel in the after shot. Very confident that if those pictures are of the same turbo and it is on your car, you have high flow job.
Dude, i only posted them for an example for the guy that started the topic :cool: That turbo was off my R34......... Was trying to help!
Thanks for the responses. Yes, 34GTT i realise that post was for me to get a better idea of what it could look like. I'm not going to be taking the turbo out though so i'm hoping that i can tell just from the housing.
i guess if it says "nissan" on it, it's stock.
No, that isnt totally correct.
You can have the stock turbo high flowed to make more power. So your turbo may LOOK stock, but the internals are far from it.
AS mentioned the easiest way is to see if the compressor inlet has been bored out. :)
Edited by gotRICE?
Another way to tell is by the cartridge. Often hi flow jobs consist of putting a different cartridge such as a 2860 or 2871. The casting of the cartridge looks different to that of stock, If its a relatively new hi flow, the cartridge will look newer and with less rust.
I sent a stock RB20 turbo off to hypergear to get high flowed, and when I got it back the centre housing of the turbo looked quite different to before, obviously very clean, but also different, so posting a pic of that as well might help?
What sort of power did the RB20 make after you got it back from Hypergear? and was there much difference in the low to mid range response? am considering doing the same.
Mike.
coz he originally bought it already moded and has NFI?
a couple of the cars i sold were sold on rep, the new owners have NFI whats in them and if they arent in contact with me when they sell then they never will
equally so many people get their cars done at shops and dont ask questions
Mike.
Am getting it tuned very shortly, hopefully next week, but on whatever tune is running it spools up well, no power after 5000 rpm, but it's got some weird chip in the ECU that will be gone for a Nistune and should make some good power, looking like it will be great value for money, watch the RB20 upgrade thread, will be posting there after the tune, but for the money, so far recommended.
Didn't mean to hijack, carry on.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
