Having just purchased a Hybrid FMIC kit I was a little dismayed to learn I had to cut a 3" hole in the front of the chassis rail, so that the return pipe can be plumbed to the standard throttle body. Having spoken with the shop I bought it from, they said that it was normal procedure for most front mounts to have to do such a thing, which I guess was to be expected.
I however was wondering if this is what any of you guys have had to do, and will cutting a hole in the chassis rail affect the roadworthiness of the car? Having read the thread about the 3 week blitz on imports in Melbourne I’m not really interested in any nice yellow windscreen decals if you catch my drift…
https://www.sau.com.au/forums/topic/38841-mounting-a-fmic/
Where you cut the whole is only like 1mm thick steel, so it wouldnt alter the strength or weakness of the car at all.
If the police are looking down in there, then there is alot more things you will get defected for anyway.
Never heard of defect for that tho
https://www.sau.com.au/forums/topic/38841-mounting-a-fmic/#findComment-787055
when i bought my car it had a 3 inch hole cut into the side of the chasis rail. i don't have an FMIC, but someone must have had one there during the cars lifetime. i didn't know what it was until i realised it was for an fmic. it's not sheet metal i can tell you that. my car passes raodworthy and everything with it, i don't think they even see it down there.
https://www.sau.com.au/forums/topic/38841-mounting-a-fmic/#findComment-788846
Yeah nice set up Team Krazy, but for just over $1k i'm pretty happy. You'd be surprised how thin the rails are trough the cab area are knore. And You'd be hard pressed to get picked up on it, but my fear is that i'll be the lucky one that gets canneries and have some major problems getting her back on the road (ie permanently un roadworthy... crush town.) Now i'm being an over paranoid engineer... At the end of the day i've bought it, I'm gunna use it, just looking for advice
https://www.sau.com.au/forums/topic/38841-mounting-a-fmic/#findComment-789956
Cutting into your own car is always hard.
But the process of cutting the hole is a peice of cake, a 3 inch hole saw attachement and a decent drill as people have already mentioned, is all you need. I would also grab some soft rubber tubing that you can split and use to run around the edge of the hole you cut, covering the sharp edges and giving it a tidier look.
https://www.sau.com.au/forums/topic/38841-mounting-a-fmic/#findComment-791279
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
