Hey guys my car seems to have come across a 'common problem' with the v35 coupe but is a little different and sounds more serious then others..
anyway i started the car this morning only to notice these problems
- VDC, SLIP, AT CHECK all lights on
- No speedo or tacho
- No indicator arrows blinking (although indicators were actually working)
- No wipers (they would come on some times)
- sluggish and rough changing gears
- Headlights were flickering and flashing even when they were switched off.
- Stereo and a/c working fine, seats, mirrors all working fine?
Now the battery seems fine..
however I was driving through some quite heavy rain last night on the highway.. could this be an issue?
I've also read that this sometimes happen when break pads need replacing.. are they easy to check how much pad is left? if so whats involved?
would really love some help/advice asap as the car was supposed to be put on the market this week!
thanks in advance guys
https://www.sau.com.au/forums/topic/388411-electrical-issues-v35-coupe/
I can't see how worn brake pads can cause this..??
Sounds more like a power related issue.. possibly bad ground points.. Sorry, I don't have a difinitive answer for you.
fuse boxes.
one in the drivers kick panel, one in front of the battery, and one behind the battery. youll need to take off the cover and get the battery out to get to it. there are a LOT of fuses in there
