Hey guys my car seems to have come across a 'common problem' with the v35 coupe but is a little different and sounds more serious then others..
anyway i started the car this morning only to notice these problems
- VDC, SLIP, AT CHECK all lights on
- No speedo or tacho
- No indicator arrows blinking (although indicators were actually working)
- No wipers (they would come on some times)
- sluggish and rough changing gears
- Headlights were flickering and flashing even when they were switched off.
- Stereo and a/c working fine, seats, mirrors all working fine?
Now the battery seems fine..
however I was driving through some quite heavy rain last night on the highway.. could this be an issue?
I've also read that this sometimes happen when break pads need replacing.. are they easy to check how much pad is left? if so whats involved?
would really love some help/advice asap as the car was supposed to be put on the market this week!
thanks in advance guys
https://www.sau.com.au/forums/topic/388411-electrical-issues-v35-coupe/
I can't see how worn brake pads can cause this..??
Sounds more like a power related issue.. possibly bad ground points.. Sorry, I don't have a difinitive answer for you.
fuse boxes.
one in the drivers kick panel, one in front of the battery, and one behind the battery. youll need to take off the cover and get the battery out to get to it. there are a LOT of fuses in there
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
