Hi,
I'm pretty sure that the turbo on my r33gtst s2 has just let go.
Waiting to confirm with the shop but no boost and lots of noise from turbo. Doesnt look good :-(
Anyone have anything local for sale?
Anyone know a local place to get the turbo Hi flowed? I asked one mob and they said it cant be done as it has ceramic (I thought the whole point was to replace with steel!!)/
Lastly, If I do go a larger turbo any thoughts on setup? I been reading a bit on the forced induction forums but too many options for me.
My car is relatively stock with Dump pipe,Turbo back exhaust, etc. Has recently had a h/duty nismo clutch put in it.
Thanks in advance for any suggestions
https://www.sau.com.au/forums/topic/388415-require-a-new-turbo/
Jump on the hyper gear website and have a look at their direct bolt ons
Also if yours isn't cracked you can send yours off to them and for around $900 they will repair and highflow it
Probably the best option for a stock setup unless your aiming for higher numbers then you have to start looking at other things
Around 190-210 maybe but you would need a tune so if your going cheap then maybe looking into an apexi safc
That will allow you to lean out the top end making better power. Right now with that setup will make te standard computer run pretty rich because it will trip put with all the air running in and just rich it up to be safe
What goal are you aiming for and we can tell you what Oi would need.
:ph34r: Dont take your car to the mob who said ya cant because the wheel is ceramic lol
Hi,
GCG turbo's can high flow it, no idea of price though but they have a very good reputation.
Might be worth having a read of this thread, http://www.skylinesaustralia.com/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/ check for other people running a similar setup to you and see what their results are like. Might give you some idea of which way you want to go.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
