I look for the longest hills I can and run up them at high gears at medium revs with medium throttle (make sure it's not too much load, pinging would be "a bad thing"). And when I say no boost, I mean as little as possible - turn off the boost controller and just run wastegate boost. A run to somewhere like bathurst up bell's line is perfect.
Also, you should avoid engine braking on the way back down, it's not good for a motor running in.
Alternatively, it is dead easy on a dyno because it creates the load you want - its much quicker that way but not everyone has one handy :(
sorry nfi, but I have been told this by more than 1 good tuner. I assumed that acceleration and deceleration have difference forces on the bearings that matter during the first few klm.
BTW, I should add, running in a motor is about getting the bearings seated correctly in the first very short time, and then about the piston rings bedding into the bores for the remainder. If you do a compression test before and after run in you will find a very large difference eg 130psi vs 180psi.
The only other important thing is to change the oil nice and early so anything that was missed in the clean, and any ring and bearing run in material is gone. Here is an oil analysis I had done on run in oil:
Long short a mineral oil with the lest friction modifiers additive package . Cheaper Castrol in whitish grey bottle is fine .
If really keen change it and filter after the first test drive .
As above go find the longest mountain to climb and drive up it at low/medium revs and WOT .WOT gives the best cylinder filling and highest cylinder pressure to get behind the rings and push them out against the cylinder walls . Its the extra pressure the rings exert on the bores that allows the cross hatching to wear a working surface on the faces of the rings and bores .
Turbo engines are easier if anything to run in because you have a physical pump to raise cylinder pressures and get the rings pushing out onto the roughened up (honed) bores .
It really doesn't take very long to get a working surface on the crankshaft bearings if the block and crank journals are to spec .
At 400 I call my engines run in enough for a dose of good mineral oil and after 2000 more its over to what ever I intend to run the thing on .
Never ever had a problem with a freshened engine that was honed or bored and honed properly meaning round parallel cylinders and always used chrome rings .
A .
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 😛   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
