Hi All,
I've just been looking on the DBA website for some new rotors but it looks like they are only making them for Brembo calipers. I've had a bit of a search and not really come up with much as far as options. I don't want to upgrade my brakes or add spacers/brakets ect ect just to accomodate for the larger DBAs.
So my question is what are my options for keeping the standard calipers, the car's not a daily and I'd like to start doing some light track work with it soon. So looking for something slotted.
https://www.sau.com.au/forums/topic/388449-r32-gtr-sumitomo-calipers/
Just look for R33 gts-t. Same thing.
Get RDA, better value if you are only doing the odd track trip in a stocker car.
Pretty sure gtst rotors 2mm thinner, ie 30mm while early gtr is 32mm.
+1 for RDAs.
Hi mate,
DBA definitely do your rotors in 4000 series slotted, and for track work would be the ideal option. Made in Australia, high carbon content (for better performance and longer life) and thermal marking paint to monitor track temps. To suit your car are $198 each for the front, and $148.50 each for the rear.
They fit, but they're not the same thing. The GTR rotors are 2mm thicker than the GTS-T. Doesn't sound like much but thermal mass when you're chasing performance is significant.
They're cheaper, but when being used hard won't last as long as the 4000 series, so some of that cost saving is offset by that. RDA slotted to suit are $349 for the front pair, and $185 for the rear pair.
Going up from that would be something from Project Mu, but the pricing gets fairly serious also.
Any questions at all just let us know!
Regards,
Greg
Ah ok, 2mm - fair point.
You can get the RDA under $300 a pair for fronts if you shop around. Could go through 1.5 sets of RDA for the price of one set of DBA. Comes down to what the end user wants/budget as there is nearly 40% price difference.
RE: Rotor wear. It is as much about pad choice in terms of how long a rotor will last. Get a pad that is hard on rotors, and rotor composition will be the least of your worries.
I've got the new club spec slot 4000series on my 32gtr.
Got the whole set for 600(4 rotors).
Keep looking, they are on the website.
From memory, not with the rest, have to go down the list a bit.
A couple of years back bunch of us had 4000's crack with track use (the thread should be easy to find). Are they any better now?
Yep, it was mainly down to the old slot design. Same reason the 5000 series in the old design never had that extra little slot on the outside that the 4000 did.
I'm in now way knocking RDA (well sell thousands of their rotors every year with never a problem) but when used with an aggressive race or street pad, the DBA will easily pull back the 40% price difference in terms of rotor life.
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
