Hey guys,
Time for a change - so selling my R33.
Its a 1993 S1 GTS-T two door in black (well most of it is black).
Odo reads 170k (but its probably been wound back like the rest of them).
Mechanically its outstanding for a car of its age - the whole reason I bought this thing. It pulls cleanly and has always been serviced and looked after. I'm the second owner in Australia - my mate was the first and he drove this for 7ish years, like my nanna. Seriously, he is a top bloke but why he owned a skyline I don't know. We lived in Wagga so its done a lot of long range work and highway kms. I used to drive to to Sydney and back every fortnight for a few months (return trip of 1000+ kays), plus it did two trips from Wagga (4000+ kms). Been serviced heaps - I would say every 4000 odd kms.
Interior is typical of a car of this age - good condition overall (its had mats and seat covers in the front). It did have some epic freaking soft drink explosion which has been steam cleaned - but there are still some marks to help add character. Dash in in good shape, trims are all there. Seats still bolted in. Fully hektik drift steering wheel. I've got the stocker somewhere which would be ok with a cover. Its been fitted with an alpine ipod head unit (which works great) and some pioneer 6 inch speakers.
The A/c has been removed to add both street cred and aid in cooling - the parts are all there and if you really wanted to you could put it back in (or you could harden up a bit).
Its sitting on R32 GTS-T stock rims with decent rubber (two of them almost new).
Mods include all the usual lower end stuff - front mount intercooler, boost controller, full 3 inch exhaust (turbo back) with a hi flow cat. Its not too loud (I'm old) but still sounds good on boost.
It's also got a Nismo 2 way diff and Jim Berry full monty clutch.
King springs with some aftermarket shockies - rides and handles pretty well.
The paint is pretty rough. Its lived outside for a fair chuck of its life in aussie - and at some point the horizontal surfaces were re sprayed with an acrylic. The roof it especially bad. The bonnet has been resprayed in rattle can black mat which was an upgrade from how bad it was, Not the greatest job. The body as reasonably straight with a few minor blemishes. So you could paint it, or get over it and just enjoy it the way I have been.
Its got 4 months rego still on it - however you'll need to get your own safety cert. It did pass one late last year (to get regoed up here) so there isn't anything "wrong" with it. Plates are not included - it'll just have stockers on pickup.
$5.5k obo. I think the price is pretty fair for a running, regoed GTS-T. Just needs some paint.
Please don't bother texting, or messaging me here. Real buyers make calls 0418 six six six 332. 56
https://www.sau.com.au/forums/topic/388450-r33-gts-t-usual-light-mods-cheap/
Back for sale due to a freaking time waster.
Please note: Don't text me with offer of your 4wd / falcodore / whatever. If you've got money and would like to buy a skyline give me a call.
Also, make sure you have permission from the mrs.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
