Hello guys and girls, my car is now for sale.
It will be a regretful sale as the car has come a long way since i first bought it but my priorities have now changed.
Not in a hurry to sell so please do not bother with the low balling..
1995 R33 GTR V-Spec
Midnight Purple
120,300kms
Pics:
Engine:
Unopened RB26DETT
Gates Timing belt
Tomei Type B Poncams 260 IN/EX 9.15mm lift
HKS Adjustable Cam gears
Sard 700cc Injectors
Garrett GT3582R 0.82
Custom teflon braided oil and water lines.
6Boost Custom manifold
44mm Tial wastegate with 3" stainless screamer pipe
3" Custom stainless steel dump pipe with flexi
HKS 3.5" Mild steel cat back
Splitfire coil packs
NGK BCPR7ES Spark plugs gapped to 0.80mm
Triple core radiator
Trust 100mm drag intercooler
K&N 6" pod
Front mount Oil cooler with oil relocator kit with braided lines to and from the oil cooler and engine
OS Giken STR 2CD Twinplate clutch
Braided clutch line
Aluminium air guide
Greddy oil filler cap
Apexi 1.3bar radiator cap
Custom Washer bottle / Oil catch unit
Bosch 044 Intank fuel pump
Brakes & suspension
BC BR Coilovers (height and damper adjustable)
Factory Brembo brakes all round
Remsa front pads
Bendix rear pads
DBA 4000 series rotors (front and back)
Wheels
Work Meister S1
Chrome dish gold center
Front: 18x10 -15
Rear:18x10 -2
Project Kics wheel nuts in Titanium Blue
Wrapped in Federal 595 ss 245/40/18
Exterior
Body coloured lip
Nismo clear side indicators
Rear pods
Interior/Electronics
Apexi Power-FC D-Jetro with Hand controller
Apexi RSM
Apexi EL2 boost, oil pressure, oil temp and water temp
Apexi EL2 Control unit
Greddy Profec b spec 2 Electronic Boost controller
Greddy turbo timer
Nismo 320km/h 11,000rpm dash
Nismo upgraded centre console 3 gauge cluster (Front Torque/Oil Temp/Boost)
Pioneer deck
Hertz Front splits
Dynamat on both doors
6000k HID Kit
White LED's for center gauges,cluster and aircon unit
Darkest Legal 35% tint
Current tune
485.9hp at all 4 hubs on 20psi – Tuned by Sean @ ASG. Could have made more power on the same boost but was tuned for my piece of mind.
Dyno Graph
Some things you might want to know:
The engine is in excellent condition, I have compression tested it twice since owning it got 170psi accross all cylinders both times.
I am more than happy to do this test again for interested parties.
The engine had its first 100,000km service at 66,000km before i owned it. Timing belt, bearings, water pump, seals etc were all changed.
When I installed the poncams 4,000kms ago I changed the timing belt and bearings again just to be on the safe side even though they were in pretty good nic.
I have serviced the car myself every 5,000kms with fully synthetic penrite oil, the gearbox has redline lightweight shockproof which is less than 1,000kms old.
Transfer case, front and rear diff oils were changed under 10,000kms ago.
The engine has no leaks, it is spotless and always has been.
The body isnt perfect (or maybe im just too fussy) so dont expect a showroom condition GT-R, it has a few imperfections but the colour seems to hide them quite well which is why they never really bothered me..
I will let the car do the rest of the talking as a quick drive will get your blood rushing :)
Price: $29,000
Call 0401 564 822 or send me a PM if Interested.
More pics available here:
http://imgur.com/a/VqMRq
Edited by snozzle
https://www.sau.com.au/forums/topic/388457-perth-mp-r33-gtr-v-spec/
HOTTTTTTTTTTTTTTTTT
im in the market for another r32 gtr with a set budget....hmmm might be time to stretch the budget :P
goodluck mate this will get snapped up real quick
I am happy to ship the car via train anywhere in aus for 29.5k :)
Flights are cheap these days! jump on a plane in the morning, check the car out and be on your way at night! I can help with transport to and from the airport too, no problem there guys!
Oh it's more getting it registered in this state, almost impossible unless $ in engineering fees. Nice car either way!
Fair enough bud!
Agreed, this car is a great buy. Always enjoyed seeing the build thread pop up with new updates.
Whoever gets it will definitely enjoy it no doubt.
Haha cheers, I'm still waiting for the results from your beast ya know!
  • 3 weeks later...
  • 1 month later...
Price drop to $28,000!
I may consider a revised price if you BYO wheels but i really cannot be bothered removing anything else and I am no longer interested in swaps as I have a new daily lined up already.
  • 3 months later...
  • 3 years later...
    • If you really don't want to touch anything you can try to trigger off the timing loop just to see if it's sparking semi-regularly. Don't trust it for actual timing measurements.
    • Also replace the fuel filter aswell today
    • Hey everyone, I have a r34 GTT s1, im having a problem with my skyline, ive let the car sit in the garage for the last couple of months and havent run it and ive gone to fire her up today and it cranks but doesnt fire, i have been having problems with it previously where it wouldnt start again after driving it around for a bit. It use to start fine on cold start ups but if you drove to the petrol station and fueled it up and went to go start it again, it would just crank and not fire untill you let it rest for a few hours, the car doesn't over heat it sits perfectly in the middle while driving when warmed up. Im thinking this problem has caught up maybe and now it just wont start at all. The car runs on e85, ive checked the e85 seems to be fine. I can hear the fuel priming before you go to start it and checked all my fuses and relays. List of things I replaced today - New battery - New sparkplugs - New Coolant temp sensor I was thinking about testing the CAS but from what ive seen online, if the CAS is cooked, the car will actually start up but then die instantly? as mine just doesn't fire at all. Does anyone have any idea or have encountered the same problems? thanks
    • Modern reg stuff now, they'd have a wide input range which would push through a buck converter, it would need to be able to maintain voltage for cranking conditions (sub 9V at times). Likely runs something like an internal 6V rail, and then further voltage regulators depending on which circuit/area it is feeding. Modern voltage regs, like what I'm starting a new power supply design with at work, will let me run a 5V rail output, and as long as my input is equal to or greater than 5V, I have a 5V output. Except I'm not pushing a 5V rail in our system as I don't need one, we're setting up for a 3.8V rail. Our new design will allow me 6 to 60VDC input, and everything else doesn't care, even when I start pushing a few Amp outputs.   Realistically, the voltage drop off could be caused by a few things though, one could be literally the alternator is dieing, and hence charge power is dropping, which also means on a straight hard pull you're starting to send the battery flat... (Not that likely from a single couple of gear pull if the battery was fully charged). However, having earth issues, like stray earths not connected, or someone having put a ground loop in, will see the ECU appear to end up with lower voltage "input", mainly because the "ground" is no longer equivalent to battery negative. If they're comparing the input voltage using sensory ground for example, and sensor ground is what is in that ground loop, than the sensor output voltage will actually start to be reduced, when compared to battery ground... Yeah, ground wiring design can start to be a bitch... Also voltage going weird from inductive loads not being managed properly is another real bitch... Hence, why I asked above about how everything was wired in. If OP knows, and can post all of the actual connections from the ECU pin out, as well as what wires are joined where in the loom, which grounds from the ECU have ground points and where they are etc. Would help to see if there is a ground issue. The part I'd start with though, is putting a mechanical oil pressure gauge on to confirm the theory. Otherwise the next track day when the threshold is lowered could result in another of @Duncan favourite types of jokes... Knock knocks... Pretty sure this is what @GTSBoy is also self high fiving...  Is all great that we have a decent theory... But they need to prove it before relying on it...
    • When I worked at BlueScope Steel, we had an Ethernet network, with every switch setup with a duplicate switch. Even when looking at all the primary switches, they had duplicate links, there was then also duplicated links between the primary in section A, to the duplicate in section B. So for each location that had networking, there was 8 network links. This was all back around 2007. That setup caused sooooo many issues, as many of those links were fibre. The network guys ran everything with Spanning Tree Protocol. And then we had great joy... The FOC Transceivers were slowly dieing, but in an intermittent way. And a lot of the time as they started to die, they'd drop offline for about 30 seconds... Spanning Tree Protocol was requiring 45 seconds to "rewire" the network... And by the time it was mostly finished, it had to start again as the transceiver was back online... Queue entire production network being constantly spammed with the spanning tree protocol messages...   My god I do NOT miss working in huge environments like that!
