Hello guys and girls, my car is now for sale.
It will be a regretful sale as the car has come a long way since i first bought it but my priorities have now changed.
Not in a hurry to sell so please do not bother with the low balling..
1995 R33 GTR V-Spec
Midnight Purple
120,300kms
Pics:
Engine:
Unopened RB26DETT
Gates Timing belt
Tomei Type B Poncams 260 IN/EX 9.15mm lift
HKS Adjustable Cam gears
Sard 700cc Injectors
Garrett GT3582R 0.82
Custom teflon braided oil and water lines.
6Boost Custom manifold
44mm Tial wastegate with 3" stainless screamer pipe
3" Custom stainless steel dump pipe with flexi
HKS 3.5" Mild steel cat back
Splitfire coil packs
NGK BCPR7ES Spark plugs gapped to 0.80mm
Triple core radiator
Trust 100mm drag intercooler
K&N 6" pod
Front mount Oil cooler with oil relocator kit with braided lines to and from the oil cooler and engine
OS Giken STR 2CD Twinplate clutch
Braided clutch line
Aluminium air guide
Greddy oil filler cap
Apexi 1.3bar radiator cap
Custom Washer bottle / Oil catch unit
Bosch 044 Intank fuel pump
Brakes & suspension
BC BR Coilovers (height and damper adjustable)
Factory Brembo brakes all round
Remsa front pads
Bendix rear pads
DBA 4000 series rotors (front and back)
Wheels
Work Meister S1
Chrome dish gold center
Front: 18x10 -15
Rear:18x10 -2
Project Kics wheel nuts in Titanium Blue
Wrapped in Federal 595 ss 245/40/18
Exterior
Body coloured lip
Nismo clear side indicators
Rear pods
Interior/Electronics
Apexi Power-FC D-Jetro with Hand controller
Apexi RSM
Apexi EL2 boost, oil pressure, oil temp and water temp
Apexi EL2 Control unit
Greddy Profec b spec 2 Electronic Boost controller
Greddy turbo timer
Nismo 320km/h 11,000rpm dash
Nismo upgraded centre console 3 gauge cluster (Front Torque/Oil Temp/Boost)
Pioneer deck
Hertz Front splits
Dynamat on both doors
6000k HID Kit
White LED's for center gauges,cluster and aircon unit
Darkest Legal 35% tint
Current tune
485.9hp at all 4 hubs on 20psi – Tuned by Sean @ ASG. Could have made more power on the same boost but was tuned for my piece of mind.
Dyno Graph
Some things you might want to know:
The engine is in excellent condition, I have compression tested it twice since owning it got 170psi accross all cylinders both times.
I am more than happy to do this test again for interested parties.
The engine had its first 100,000km service at 66,000km before i owned it. Timing belt, bearings, water pump, seals etc were all changed.
When I installed the poncams 4,000kms ago I changed the timing belt and bearings again just to be on the safe side even though they were in pretty good nic.
I have serviced the car myself every 5,000kms with fully synthetic penrite oil, the gearbox has redline lightweight shockproof which is less than 1,000kms old.
Transfer case, front and rear diff oils were changed under 10,000kms ago.
The engine has no leaks, it is spotless and always has been.
The body isnt perfect (or maybe im just too fussy) so dont expect a showroom condition GT-R, it has a few imperfections but the colour seems to hide them quite well which is why they never really bothered me..
I will let the car do the rest of the talking as a quick drive will get your blood rushing :)
Price: $29,000
Call 0401 564 822 or send me a PM if Interested.
More pics available here:
http://imgur.com/a/VqMRq
Edited by snozzle
https://www.sau.com.au/forums/topic/388457-perth-mp-r33-gtr-v-spec/
HOTTTTTTTTTTTTTTTTT
im in the market for another r32 gtr with a set budget....hmmm might be time to stretch the budget :P
goodluck mate this will get snapped up real quick
I am happy to ship the car via train anywhere in aus for 29.5k :)
Flights are cheap these days! jump on a plane in the morning, check the car out and be on your way at night! I can help with transport to and from the airport too, no problem there guys!
Oh it's more getting it registered in this state, almost impossible unless $ in engineering fees. Nice car either way!
Fair enough bud!
Agreed, this car is a great buy. Always enjoyed seeing the build thread pop up with new updates.
Whoever gets it will definitely enjoy it no doubt.
Haha cheers, I'm still waiting for the results from your beast ya know!
  • 3 weeks later...
  • 1 month later...
Price drop to $28,000!
I may consider a revised price if you BYO wheels but i really cannot be bothered removing anything else and I am no longer interested in swaps as I have a new daily lined up already.
  • 3 months later...
  • 3 years later...
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
