  • 3 weeks later...
  • Replies 69
No worries Leon! I think everyone has theirs now, and I'm doing the rounds for the local guys at the moment.
Mine are going in tomorrow, can't wait to get it all aligned!
Yep, I posted updates in the thread in the group buy section. Just organising to get them to all the Adelaide guys at the moment.
Last of the order arrived yesterday!
  • 2 months later...
I was telling my alignment guy about the 'Control Arm Upper-Inner Eccentric Kit - SPF3297K' & he asked how they were adjusted. Similar ones he has worked on in the past had some way moving the eccentric tube to give the desired setting.
I can't see how that is done on our Superpro ones. Do they get installed at the maximum adjustment available & then finely adjusted some other way or is their something I'm missing?
Scrap that question. Looked up the web site & says instructions are enclosed :blush: . These only do +/- 0.5 degrees correction so it appears you just set & forget. Happy days.
Yep. Seems to work well, but I guess you need the adjustment depending on the alignment of other components and how worn they are, so you can adjust to the right deg and set and forget.
Mine isn't getting driven at the moment, just too much on, but next month I'll be replacing the rubber and getting it realigned, because while it feels good I'm not happy with the alignment. Rubber is stuffed, and camber worn, so it still pulls no matter what the alignment guys do.
