  • 2 years later...
Gudgen retaining clip failed and the pin cracked the cyl wall.  That engine did see nearly 9,000 Rpms and I was the one that put the retaining pins in so who knows why it failed.  New build is an RB26/30 now so revs stay below 8k and with the torque curve and turbo set up, no need to rev past 7.5k.
  • Like 1
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
