well just got a heap of detonation on my 25 and have decided to pull the motor down and rebuild it.......again, the only things im going to need to change will be pistons,headgaskeet and new bearings.
i have done the n1 pump,oil pump drive gear,oil restrictors,26 rods,arp studs everywhere blah blah blah.
chasing 400hp and i know a standard 25 will do it but im wanting a bit of safety so decided of forged pistons and cometic headgasket, what brand pistons are doing well in 25's at the moment and what ones to stay away from, going to be boring it out 40 thou aswell.
tim
https://www.sau.com.au/forums/topic/388464-rb25det-forged-pistons/
Sounds too far fine to even bother comp testing if you are getting oil ontop of the piston...
Its kind of hard to say. I do know you can get drop in forged pistons which fit the standard bore but do you know if your bores are good? Is the crack still fine? Lots of things to check. If you were upgrading a healthy motor it would be fine, buy if you got a heap of detonation, you need to sus it out. Even head valves, are they still good?
Hyper gear on here has replacement pistons, I think cp make direct replacements.
Why?
Only go as far as you require.
Get a set of Weisco/CP/Mahle from the states. All are good, little issues with any really. More about getting the numbers/build right.
My engine builder said to avoid mahle, they are apparently very loud and the way they are made you have to bend the oil squirters. I just got a set of 86.5mm cp for $800 delivered.
everyone who doesnt have mahles seams to say that yet i've never heard any complaints from people actually using them
If squirters squirt oil through a gallery in the bottom of the pistons into the rings then yes my 25 does.
My new cp pistons don't have the gallery. I just hope that isn't going to cause too many problems.
Edited by lilcrash
The issue is the pistons are solid across the pin supports?? There is no cut out for the squirters in mahle pistons.
I can tell you 100% certain that my block is stock rb25 and it has squirters.
Rb26 and rd28s have the block mounted squirters,
Rb25de/t don't so your most likely using rb26 squirters
lilcrash might suggest another machinist if he is having issues with a basic piston like mahle
je and cp are what id recommend
Dude no offense but you are 100% wrong.
Rb25 definitely have squirters.
Every rb25 I have had the sump off has had more squirters than a Asian porno
tim
valves?
25 valves are knowing to be soft and get worse with age, may not need them but i would change them to be safe.
Valve float you mean...? Not the actual valves...
It's very hit and miss debate that one. Lots of people are fine, lots of people aren't.
If the head is in good condition it shouldn't really be a problem as the aim is very moderate, so there won't be a big huffer going onto it. One of the things you don't really need to "do" unless it is actually a problem.
Plenty have made 350-400rwkw on stock heads without changing the springs.
Ye some get to 300rwkw and get valve float. Suck it an see i say.
http://ipg-supertech.com/cart.php?target=product&product_id=1300&category_id=853
take advantage of the aus to american dollar (but thats if you want to go all out nuts with the head) then you'd prob want cams, then solid lifters, then porting next thing you've spent around 4k in parts and labour on just the head
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
