been looking at cp alot,and want to have that little more displacment but yer depends on what the bores look like, head was serviced less then 8000km ago, thinking bout throwing some springs and a high lift cam in to get more mid range/top end. but once again depends on condition of valves etc to see how far i go there.
I have done something similar i used CP +40 8.5.1 comp pistons and Manley con rods arp2000 bolt set and found no problems with them. All RB25DET engines have block mounted oil squirters.CP pistons dont interfere with them
when getting your motor bored you also might want to get the block decked crank tunnels honed and final hone in yor bores done with a torque plate
I would recomend at least replaceing the valve springs with new standard ones and get the head decked as i think the pistons from usa are slightly lower comp and get the valve seats done
I was told that i would lose performance and later turbo spooling beause of the lower comp pistons but i had the head and block decked and fitted a greddy manifold and got rid of about 4 feet of turbo pipe work
and found if anything turbo spools faster{hi-flow}.
well just got a heap of detonation on my 25 and have decided to pull the motor down and rebuild it.......again, the only things im going to need to change will be pistons,headgaskeet and new bearings.
i have done the n1 pump,oil pump drive gear,oil restrictors,26 rods,arp studs everywhere blah blah blah.
chasing 400hp and i know a standard 25 will do it but im wanting a bit of safety so decided of forged pistons and cometic headgasket, what brand pistons are doing well in 25's at the moment and what ones to stay away from, going to be boring it out 40 thou aswell.
tim
That is correct, springs not valves, the thing is tho how much does it cost? The engine is out and head is off if it is not that expensive may as well do it for piece of mind
Yes the head is off... Realistically though it does not need touching at all.
It's just a case of sort the bottom end, bolt the head back on, away you go.
I have 9.0 compression CP pistons. They can do custom jobs but they cost more as they are not off the shelf.
Pity they are only 8.5 compression, I would be interested in 9-9.5. My car only runs E85 so I would look at ~9.5.
i got another head sitting here that i can get somework done on and allways bolt it up later, kind of interested in doing a oil drain from the head aswell while its out.mayby a decent set of springs and get some sure cams for it as well with about 9mm lift
You don't need an external drain if you put proper sized restrictors in that match against the oil flow you will have.
It's funny people haven't needed them at all really before, and the last 18 months they are the latest rage... And are basically a band-aid type solution.
  • 3 weeks later...
25s don't have squirters
Hey buddy, sorry to burst your bubble, but the RB25DET does have oil squirters. They are in the bore and are used for lubrication and for crown cooling.
By the way, I would have gone with JE Pro Series Pistons if you had the dosh. I am using them in my current rebuild as they come standard with Nitrite coated rings and tool steel gugeon pins. I chose Manley H-Beam rods with ARP 2000 rod bolts.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
