Just seeing what people think of my set up, ive been browsing the rb20 upgrade page and ive noticed that people with a similer set up are getting around 30rwkw more then mine.
my set up is the following
Rb20DET 110000km
Nistune ECU
Blits FMIC
K&N pod
Rb25 turbo @ 14PSI
CES racing 3" split dump
High flow cat
3.5" RS*R cat back exhaust
Walbro 500hp fuel pump
Turbo tech boost T
Ive had the car tuned twice in the current set up, first was with the auto in it, 2nd when i converted to manual. On the manual one power jumped 20rwkw and a it took 4 hours to tune.
BTW my fuel econermy is 12L/100km
https://www.sau.com.au/forums/topic/388467-my-set-up/
Why did the tuner stop gaining power?  Was it because you were running out of injector?  If your injectors are sticky/dirty and can't flow the fuel, then the mixtures will either get lean or the tuner will stop pushing when he sees the duty cycle maxxing out.  That would be my number one guess.
FWIW, my RB20 has 040 pump, std injectors, std turbo, similar dump to yours, big cat and 3 inch exhaust, old old intercooler made from a cut down truck core (back when proper coolers were $2000), and makes ~170rwkW on a dyno that reads similarly to most other DD dynos (ie not a happy dyno and not a sad one). My injectors are pretty much maxxed out at that point. They've never been out of the engine, but I have no reason to believe that they're especially dirty. Oh, and my AFM is running out of headroom at that level too. When you get them up over 180rwkW or so, you are running past the end of the AFM's scale most of the time and relying on having enough fuel in the last column of the map to cover bigger loads that aren't measured properly.
Edited by GTSBoy
https://www.sau.com.au/forums/topic/388467-my-set-up/#findComment-6191082
Some thoughts,. There is no way an R33 turbo should be hitting boost later then my TD06-20G.
How well do you know your tuner?
I personally would fit a section of flanged pipe in place of the cat for tuning. Have a close look at the boost controller as an R33 turbo with an R32 actuator will run about 13-14psi and probably hold boost better then that setup in it.
At the end of the day the dyno readout is just a figure but I cant believe it would be that far out and suspect you are right that the setup has more in it.
Also the fuel economy seems bad as well. I get about 12--14L/100km potting around city driving. On the highway I get between 9-10L/100km. So perhaps make sure your AFM is clean and the O2 sensor is functioning correctly too
https://www.sau.com.au/forums/topic/388467-my-set-up/#findComment-6191100
Thanks guy.
I havnt done a compression check since I had the car.
As for the tunner he is consider the dest in Darwin and one of only two recommended to me. I'm not shore about the injectors, and he didn't mention any thing to me about them.
Fitter the 33 turbo came with a his adj acctuator but I could only get it to 8psi with a boost t, so I sealed it to the 32 stock actuator.
https://www.sau.com.au/forums/topic/388467-my-set-up/#findComment-6191200
You are only running 12psi up top.
160rwkw doesn't sound out of the norm. It's probably in similar ball park to to running 8-9psi on a RB25 in the top end, which would make around that. Maybe 10rwkw more (so call it dyno variance).
So look to fixing the boost control and you should be fine.
Also you are in a hot climate, this plays a factor.
https://www.sau.com.au/forums/topic/388467-my-set-up/#findComment-6191208
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
