Spool RB32 Stroker Kit
Coming Soon
SPOOL RB30 91mm Stroker Crank Kit
Nissan RB30 - RB32 Stroker Kit:
  • SPOOL Billet 4340 full counter weight 91mm Stroker Crankshaft
  • SPOOL I Beam Forged Conrods with L19 Bolts
  • CP Custom Pistons
  • 9310 Gudgeon Pins (4.5mm wall thickness)
Sawwwce ;)
Discuss.
https://www.sau.com.au/forums/topic/388487-spool-rb32/
I see your RB32 and I raise you an RB34:
http://spool.directf...roker-crank-kit
FACEPALM!
If only there was more than one RB34 thread on this forum...
Will be interesting to compare This kit to Nittos kit.
Edited by 045HOW
https://www.sau.com.au/forums/topic/388487-spool-rb32/#findComment-6192172
FACEPALM!
It would be very interesting to compare. Nitto's 3.2l kit costs a lot more than the spool 3.4 atm. Has anyone actually compared any of the spool products alongside the nitto items to compare quality and watnot?
https://www.sau.com.au/forums/topic/388487-spool-rb32/#findComment-6192773
yea thats what i was getting at... it probably comes from the same bread shop like 90% of the gear on the market
which means price war!
https://www.sau.com.au/forums/topic/388487-spool-rb32/#findComment-6194220
FACEPALM!
Apologies I thought you were unaware of the rb34 kit and had just noticed the rb32 kit.
Why would you choose the rb32 over the rb34? Cheaper? Rev higher?
https://www.sau.com.au/forums/topic/388487-spool-rb32/#findComment-6194708
I presume its cheaper. The longer the stroke the higher the piston speed at a given rpm so I guess the 32 is less stressed.
https://www.sau.com.au/forums/topic/388487-spool-rb32/#findComment-6195150
Well side by side won't tell you much other than the sizing/weight with things like rods etc.
Need to actually properly test it, install it, drive it etc.
Unfortunately there are little results around even after a bit of time :(
https://www.sau.com.au/forums/topic/388487-spool-rb32/#findComment-6195183
Totally understand where you're coming from but the cost of manufacturing a 91mm crank compared to a 94mm crank is so small it's not worth mentioning. I'd take a gamble and say the pricing will be the same as the 3.4 RRP. Any cheaper is ripping himself off, as long as it's cheaper than Nitto he shouldn't have a drama selling them
https://www.sau.com.au/forums/topic/388487-spool-rb32/#findComment-6195202
as r31nismoid said unless there is back to back comparission the only differences would be price,
i still am yet to personally see an rb34 spool kit, seen plenty of nitto r32 (probably as nitto is local in sydney and spool is qld i think)
though the customers have said they bought the 90mm stroke as they think the 95mm stroke would be an over stroke for their application,
which is along the lines of what r33_racer was saying, all depends on what the motor is going to be used for will depend on which crank is best
plus spool appear to use cp pistons
nitto use JE/SRP
(which the cp workers used to work at JE/SRP before starting their own company, so end of the day same piston quality)
in theroy the benifits/ differences i can notice other then the srokes;
nitto cranks have slight knife edging and the rods with big end oil squirters
spool cranks from what ive seen in pictures/ read are fully counter weighted aka gives the crank more throw (encourages it throw itself in the rotating directing)
https://www.sau.com.au/forums/topic/388487-spool-rb32/#findComment-6198259
I think it's more a case of there were a few NITTO strokers getting around early on. No doubt via reduced pricing for market penetration by a few places etc.
Yet the SPOOL RB34 results really haven't been seen anywhere or in at least volume of half a dozen type thing.
Understand the in-house goes first as you can't really sell something that's going to mince itself due to poor materials or something, but it's taking really long?
https://www.sau.com.au/forums/topic/388487-spool-rb32/#findComment-6199340
once again never seen a jun stroker crank, which after googling looks like a full counter weighted crank too (bout all i can tell)
seen a few normal 26 and N1 26 cranks, 2.8 HKS cranks, fair few nothing special rb30 cranks and nitto 3.2 cranks, would like to see more variety but all depends on our cutomers, plus once the machining is done most the time we rarely hear of any results
https://www.sau.com.au/forums/topic/388487-spool-rb32/#findComment-6199924
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
