  On 18/01/2012 at 10:57 PM, Harey said:
Apologies I thought you were unaware of the rb34 kit and had just noticed the rb32 kit.
Why would you choose the rb32 over the rb34? Cheaper? Rev higher?
RB34 requires some block machine work AFAIK, RB32 should be bolt in and go.
  • 2 months later...
on the spool webiste they have done a comparison chart between a rb30 and their rb34. bit of a increase has been achieved. http://www.spoolimports.com/articles-1/rb34det-results. as for brand comparisons dyno charts, it will probably never happen as not one workshop will see the same style of car, same style of setup do to this unless they cough up the coin themselves to carry out the tests.
  On 02/04/2012 at 3:19 AM, 4PIMPN said:
on the spool webiste they have done a comparison chart between a rb30 and their rb34. bit of a increase has been achieved. http://www.spoolimpo...rb34det-results. as for brand comparisons dyno charts, it will probably never happen as not one workshop will see the same style of car, same style of setup do to this unless they cough up the coin themselves to carry out the tests.
This thread is not about RB34. There is already an RB34 thread.
I'm surprised they didn't lose any hp in the top end due to the smaller bore/stroke ratio. I would say there head was flowing quiet well!
The rb34 bore/stroke ratio is less than an xr6t and those things just don't like to rev over 6500.
They used a standard NEO head and said a lot more could be done if the head had have been flowed to accommodate the larger displacement.
  • 7 months later...
True 3.2? does litre actually matter or stroke? When is the point where longer stroke stops making power?
and creates less?
Spool 3.2 stroke 91mm
86mm bore 3.17
86.5mm bore = 3.2
87mm bore = 3.24
Nitto 3.2 stroke 90mm
86mm bore = 3.14L
86.5mm bore = 3.17L
87mm bore = 3.21L
I personally think these cranks are similar as in the rips main caps and cradle and the spools version not long after
but just ask yourself, why is something cheap? What did they cut out? Was it just to make it sell easier? Or was there something that just wasn't needed?
  • 2 months later...
I think Rips latest engine in the Stagea will be revving at least 9000 but he is being a bit cagy about the actual size. I would guess its a 3.2 although he could be experimenting with something bigger.
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
