Awwwwwwwwwwwwww Yeah! :p
045HOW
 Share
Bit more info on it here guys...
http://www.nzjetboating.com/yabbse/index.php?PHPSESSID=bebea27e45e9e5a9b5f908a21730ecc2&topic=21985.0
Some engine details:
30 block - oil returns enlarged, 12mm studs, custom 3 stage dry sump, spool kit
26 head - tomei 272 10.8mm cams & springs, exhaust ported, stainless valves, oil returns enlarged
greddy plenum port matched , itb's removed, 90mm throttle body, bosch 2000cc injectors, double cored water/air intercooler, crank mounted sensor
sinco large diameter twin scroll manifold, twin tial 38mm wastegates,
Holset HX-52 turbo(non standard water cooled core 16cm2 turbine and smaller comp cover to fit my setup)71mm comp inducer.
Yes, it makes far to much power for a 15ft hull. :O
Edited by roba
 Share
    • Here’s something I was wondering. From the colour of the fuel that came out of the old filter and how hard it was to take it out, I would assume that was clogged AF! Do you think the car was running lean during those times? And would it now run better now that the flow is better? Or would it run rich for a while and then start adjusting?  I’m not really sure if the R34 ECU adjusts to changes like this. I mean it’s an ECU from 2000, not AI 😂 But also, interested to know if anything like that is there.
    • Have made a start on the dump pipe. Ordered a few 3.5 inch bends and pie cuts. To make fit up and tacking a bit easier cut some slots in an old t bolt clamp. It's been a tight fit but managedto get it down under the car but still sits about 5-6mm below the chassis rail. Have started to weld it out but not had much time. Also got new orings and gasket so intake and injectors are back in with all the water bypass done. Another box arrived with bits for making a  swirl pot off the upper coolant neck. PWR are still waiting to make my intercooler and radiator but should be ready in 2 weeks. Slowly making a plan for a few suspension arm upgrades for when all engine/driveline is done. Got a busy period for work  ext few weeks so not much will happen on the car.
    • I've had this happen with some cheaper kits and found the efihardware ones don't do this. I would go be pwm the pump no way need it at 100% all the time.
    • That's a neat unit, was looking at running the traditional setup for the race car but will look at using these now.
    • Happy days!!!! Cut my fingers a bit but managed to change the fuel filter today. It was NASTY! The fuel coming out was black.  Those clamps were just part of the tube from how long it had been. I got some injector cleaner to put in the car as well because of what it looked like.  I'll try to get the coolant done next weekend or this Sunday (now that I know how to "safely" jack up the car)
