Torque depends on the lube used. If you use the ultra torque lube, it is about 10lb different to the super moly arp lube and different again for engine oil lube.
ARP website has the information you need, if you can't find it, ring Performance wholesale or Rocket Industries, tell them the application and they will tell you what torque ARP suggest in their kits.
Every one I have done has been 70ft/lbs using the super moly and 65 using the ultra torque lube.
