TTT Posted January 24, 2012 Share Posted January 24, 2012 In 2002 melanomas and other skin cancers caused 0.12% of deaths in the US. That's number 75 down the most-common-way-to-die list. Check your family history and your skin with a GP and calculate the risk then decide yourself whether it's worth it Definitely tan with sunscreen on, I always use 30SPF and am well brown. There's nothing cool about being a crab person who turns into a Holstein cow. Cool story. do you realise that Australia is not the US? and that we are in a completely different part of the world? do you know what the figures are for Australia? Link to comment https://www.sau.com.au/forums/topic/388509-safest-way-to-tan/page/2/#findComment-6201641 Share on other sites More sharing options...
Basti Posted January 24, 2012 Share Posted January 24, 2012 i tan Link to comment https://www.sau.com.au/forums/topic/388509-safest-way-to-tan/page/2/#findComment-6201660 Share on other sites More sharing options...
KezR33 Posted January 24, 2012 Author Share Posted January 24, 2012 (edited) In Australia its the 16th most common cause of death, with around 2000 per year dying. http://abs.gov.au/ausstats/abs@.nsf/Products/B6940E9BF2695EE1CA25788400127B0A?opendocument Edited January 24, 2012 by KezR33 Link to comment https://www.sau.com.au/forums/topic/388509-safest-way-to-tan/page/2/#findComment-6201790 Share on other sites More sharing options...
JEPPE Posted January 25, 2012 Share Posted January 25, 2012 Cool story. do you realise that Australia is not the US? and that we are in a completely different part of the world? do you know what the figures are for Australia? You obviously don't understand the point I was putting across which is quite simple to see. I'm not going to put in the small effort to explain, as from your above post it looks as though you wouldn't understand even if I spelled it out. Link to comment https://www.sau.com.au/forums/topic/388509-safest-way-to-tan/page/2/#findComment-6204667 Share on other sites More sharing options...
KezR33 Posted January 26, 2012 Author Share Posted January 26, 2012 You obviously don't understand the point I was putting across which is quite simple to see. I'm not going to put in the small effort to explain, as from your above post it looks as though you wouldn't understand even if I spelled it out. I still don't see your point. Link to comment https://www.sau.com.au/forums/topic/388509-safest-way-to-tan/page/2/#findComment-6204808 Share on other sites More sharing options...
JEPPE Posted January 26, 2012 Share Posted January 26, 2012 You're obviously asking the 'safest way to tan' because the only unsafe thing about tanning is the fact that you might one day die from cancers caused by it, otherwise you wouldn't care. If you were worried about burning only then the answer is sunblock and you wouldn't bother asking the question. Relating to the Aus stats: 1.3% of deaths are due to skin cancer. The deaths that were ranked were about 67% of total deaths that year, this means that by the time you get to the last 33% they are each 1.3% or less of the total deaths. The percentage is so small that asking a forum how to be safe about this would make an insignificant difference. Hence I said check your family history and get your skin checked as it's more likely your skin type that will be the important factor, not the way you actually tan. Link to comment https://www.sau.com.au/forums/topic/388509-safest-way-to-tan/page/2/#findComment-6204902 Share on other sites More sharing options...
KezR33 Posted January 26, 2012 Author Share Posted January 26, 2012 You're obviously asking the 'safest way to tan' because the only unsafe thing about tanning is the fact that you might one day die from cancers caused by it, otherwise you wouldn't care. If you were worried about burning only then the answer is sunblock and you wouldn't bother asking the question. What? You're saying burning your skin is not unhealthy, even with cancer taken out of the equation? You might as well say sticking your hand in boiling water is safe because if you pull it out quick enough it won't do permanent damage. I was definitely not only refering to cancer. The answer is not sunblock either, because one of my questions was would sunblock prevent me from tanning. Relating to the Aus stats: 1.3% of deaths are due to skin cancer. The deaths that were ranked were about 67% of total deaths that year, this means that by the time you get to the last 33% they are each 1.3% or less of the total deaths. The percentage is so small that asking a forum how to be safe about this would make an insignificant difference. Hence I said check your family history and get your skin checked as it's more likely your skin type that will be the important factor, not the way you actually tan. IMO the number of deaths is irrelevant. You could just fry day in day out and get your skin throughly checked by a GP every few months and properly be safer than your average joe. Just because the cancer doesn't kill doesn't mean prevention is cheap or treatment pleasant. I'm sure a lot of those people who died of other causes had skin cancer at some point in their life or was suffering from it but died via other means before the cancer could get them. Link to comment https://www.sau.com.au/forums/topic/388509-safest-way-to-tan/page/2/#findComment-6205591 Share on other sites More sharing options...
macdog Posted January 27, 2012 Share Posted January 27, 2012 You guys should try a living in northern Japan where you put away the shorts and t-shirts around mid ~ late Oct and they dont come out of mothballs until June. Then your covered with snow from late Nov to May. You guys have never seen white !! I felt like a vampire hiding from the sun over Xmas and New Year period here in Oz. hope your a skier or a boarder mate!!! I'd be skiing every weekend!! Link to comment https://www.sau.com.au/forums/topic/388509-safest-way-to-tan/page/2/#findComment-6206174 Share on other sites More sharing options...
sydking Posted January 27, 2012 Share Posted January 27, 2012 Look into melatonan injections mate, people have had great results. and in theroy give your skin better protection from the sun due to more melatonin, But ill leave the research up to you. Link to comment https://www.sau.com.au/forums/topic/388509-safest-way-to-tan/page/2/#findComment-6206512 Share on other sites More sharing options...
Dani Boi Posted January 27, 2012 Share Posted January 27, 2012 (edited) @ 3 minutes. http://www.youtube.c...feature=related This guy brings the lolz. Lost it at 7:37 Edited January 27, 2012 by Dani Boi Link to comment https://www.sau.com.au/forums/topic/388509-safest-way-to-tan/page/2/#findComment-6207147 Share on other sites More sharing options...
Trozzle Posted January 28, 2012 Share Posted January 28, 2012 Don't try my method which I unintentionally used today: Fall asleep on towel at the beach while it's somewhat overcast and shitty. Wake up like 45 minutes later with the sun out, absolutely SCORCHING. Apparently it had been out for a while too. Am now a lobster. Link to comment https://www.sau.com.au/forums/topic/388509-safest-way-to-tan/page/2/#findComment-6207901 Share on other sites More sharing options...
Roy Posted January 29, 2012 Share Posted January 29, 2012 Go see your doctor. They can write you a script for a prescription drug that increases your bodies production of melanin. It makes you very photsensitive so you have to be careful the first few days that you are out in the sun and wear plenty of sun block. It can help you build up a decent tan which by itself helps build up a better tolerance for exposure to the sun. One of my old clients use to make the drug and they are now in partnership for research into better melanin releasing products. From memory when chatting to the gusy in the lab at lunch things like tyrosine and Gingko biloba mcan boost melanin production Link to comment https://www.sau.com.au/forums/topic/388509-safest-way-to-tan/page/2/#findComment-6209318 Share on other sites More sharing options...
R31Nismoid Posted January 29, 2012 Share Posted January 29, 2012 Don't try my method which I unintentionally used today: Fall asleep on towel at the beach while it's somewhat overcast and shitty. Wake up like 45 minutes later with the sun out, absolutely SCORCHING. Apparently it had been out for a while too. Am now a lobster. lol... that sucks. Last 2 days, pool side with me as white as a sheet body wise from the last few months of night shift... Come out nicely brown. Arms even darker now! 1st day 15mins shirt off, nothing else. Then SPF30+ and about an hour without a shirt in/out of the pool. Today 20mins shirt off (was 10.30am). Then SPF30+ and another 30mins or so. Obvious tan lines are obvious. My Irish skin is not so Irish and not red at all. Link to comment https://www.sau.com.au/forums/topic/388509-safest-way-to-tan/page/2/#findComment-6209345 Share on other sites More sharing options...
Birds Posted January 30, 2012 Share Posted January 30, 2012 Don't try my method which I unintentionally used today: Fall asleep on towel at the beach while it's somewhat overcast and shitty. Wake up like 45 minutes later with the sun out, absolutely SCORCHING. Apparently it had been out for a while too. Am now a lobster. Also don't make the mistake of thinking you're 100% sweet if there's no visible sun. Overcast = still UV rays, still burn and still cancer lol. Basically, you're f**ked regardless...wear sunscreen. The tan will still come with it, just more healthily. I left my arm hanging out the side of a convertible a few weeks ago...the thing turned red as f*** and after the sunburn subsided, you might be mistaken for thinking my arm belonged to Basti, but the "cool tan" lasted for about 4 days before two layers of skin peeled off and let through some VERY tender white skin underneath, which was whiter than the rest of my body lol. So fail in the end. Link to comment https://www.sau.com.au/forums/topic/388509-safest-way-to-tan/page/2/#findComment-6210191 Share on other sites More sharing options...
Trozzle Posted January 30, 2012 Share Posted January 30, 2012 Oh yeah overcast still definitely means sunburn, just not as horribly. Link to comment https://www.sau.com.au/forums/topic/388509-safest-way-to-tan/page/2/#findComment-6210221 Share on other sites More sharing options...
Melly Posted February 2, 2012 Share Posted February 2, 2012 I am 23 and have had 3 suspicious moles removed because of the sun... I don't burn, I have once and that was when I was on antibiotics that increased chance of burning, I have a light tan but not intense... Seriously my boyfriend is as WHITE as white gets and I am fine with him not being tanned because at least I know he is looking after him self... Safe way to tan, there isn't one, I had a friend who was 17 pass away from skin cancer and that was from spending too much time in the sun without sunscreen or forgetting to re-apply it... If you are going to try to tan, wear sunscreen at least it reduces your risk... Link to comment https://www.sau.com.au/forums/topic/388509-safest-way-to-tan/page/2/#findComment-6215471 Share on other sites More sharing options...
GTR-N1 Posted February 3, 2012 Share Posted February 3, 2012 Yep ^^^^ ...sad lesson indeed! Solariums in NSW to close down by 2014. Should be earlier eh what? Link to comment https://www.sau.com.au/forums/topic/388509-safest-way-to-tan/page/2/#findComment-6217819 Share on other sites More sharing options...
Trozzle Posted February 6, 2012 Share Posted February 6, 2012 I am 23 and have had 3 suspicious moles removed because of the sun... I've removed around 5 by myself. Don't even tell me how retarded I am. Link to comment https://www.sau.com.au/forums/topic/388509-safest-way-to-tan/page/2/#findComment-6221067 Share on other sites More sharing options...
Birds Posted February 6, 2012 Share Posted February 6, 2012 Meh, some people lose their skin in house fires or to hordes of rampaging zombies, I think it selfish not to enjoy our intact and perfectly healthy skin to it's full extent - tan away! Link to comment https://www.sau.com.au/forums/topic/388509-safest-way-to-tan/page/2/#findComment-6221076 Share on other sites More sharing options...
GTR-N1 Posted February 6, 2012 Share Posted February 6, 2012 I've removed around 5 (moles) by myself. Don't even tell me how retarded I am. No I won't tell you how retarded you are. Link to comment https://www.sau.com.au/forums/topic/388509-safest-way-to-tan/page/2/#findComment-6221210 Share on other sites More sharing options...
