SOLD SOLD SOLD SOLD!
TEIN HE (not HA or HR. TEIN HE's are hard to come by) Drift Spec coilovers with adjustable height, Body length and dampening. They are in EXCELLENT condition! Suit R33 Skyline. They are for sale www.japanesemotorsport.com.au on page 3 for $1700 !!!
- EXTRACTED FROM http://www.prostreetonline.com/pso/pages/p...0HE%20Coilovers
TEIN's Type HE damper has been designed for drifting performance. It has a specific damping force and spring rate to optimize an easy control. It has also adapted a full length adjustable height system for a wide range of height set ups. These combined features improve the drifting experience. The Type HE is for the driver who is seeking a complete drifting suspension.
Specified damping force and spring rate set up for drifting.
16 levels of damping force adjustment (compression and rebound together).
Teflon coating for rust prevention.
Newly designed spring seat and spring seat lock for easy height adjusting.
Full-length adjustment and height adjustment for separate setting of the height and spring preload.
Installation Time : 3 +/- hours
R33 Sold. S13 Purchased. (still staying true to Skyline - rb25det going in :P
Must sell - non negotiable $1000!!! (or will swap for any decent set of TEIN adjustable coilovers for S13 Silvia).
You will not find HE Teins cheaper than this.
0422-963-812 or [email protected]
https://www.sau.com.au/forums/topic/38851-tein-he-coilovers-for-r33/
Hey there,
How many kms have they done?
How hard have they been ridden?
How is the rubber on them? Looks like a little wear in the pics but I dunno, that could just be grease and grime.
Have you got the hook spanners and adjustment manual?
Hey there,
Less than 15,000km's. The rubber on them is perfect!!! The pictures do not justify. Not a single crack or crease. They are in excellent condition. I do not have hook spanners or adjustment manual.
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
    • So unsafe would you say now?   little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
