HKS Adjustable Cam Gears - $300ono
Std R32 GTR Turbos, came off at 105000km no shaft play were running fine but I upgraded - $250ono
Water/Oil Braided Turbo lines for twin setup - $100
Vic, Melbourne
PM or 0438 598 163
^Hey Mate you have PM
Sorry to others who have tried to PM, my inbox is not full so im not sure why they dont come through. I have cleared it completely now.
Otherwise just send an SMS.
Edited by willL
