I have it for my white r33 gtst series 2. I think it will look quite good once i put it on. I also purchased some black plastic U channel that i am going to put around were the bar was cut in order to fit the Blitz return cooler. All up i think it will be a nice contrast to the white car. Will post pics once bumper has been repainted.
make sure you are getting the HARD rubber, as the other type people sell is just like foam and is rubbish. I have some next to me that I will probably end up using for its purpose on keeping crap from going under my garage door.
otherwise the hard stuff just gets held on with screws and load washers
  • 3 weeks later...
  • 1 year later...
  • 2 months later...
Have a look on ebay http://www.ebay.com.au/itm/FRONT-BUMPER-SPOILER-LIP-SPLITTER-BODY-KIT-Nissan-Skyline-R31-R32-R33-R34-R35-/161021193827?pt=AU_Car_Parts_Accessories&hash=item257d9c6e63&_uhb=1
i'll be ordering one after seeing this
always wondered what it wud look like
because the front bar is kinda in a circle angle,but if u had like a aero kit it wud turn out reaally good as they have a bit of a bend in em.
cheers for picture.
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
