Hey All,
Just letting you know the HSCC website has been updated, along with the Drifting Tasmania website
http://www.hobartspo...org/events.html
http://www.driftingtasmania.com/
Please find attached to this post the full calendar.
I for one am keen as hell and you should all be too! Skylines make excellent track cars in all forms whether it be 100% stock standard to balls out hardcore modified and everything in between and we should all take advantage of our brilliant cars and have a tonne of fun.
If you are new and are interested but have a few questions please feel free to post up here so that others may benefit from the answers or alternatively you can send me a PM and I'll do my best to point you in the right direction.
2012 Competition Calendar.doc
Edited by zoidbergmerc
https://www.sau.com.au/forums/topic/388533-2012-motorsport-events-tas/
:mad: Only one timeattack and I'm not gonna be ready! Are they planning to use this as a tester and include more if the numbers are there or?
If it's popular, they'll do more no doubt.
  • 3 weeks later...
I dunno if this is the best place...but here's the sup regs for Test and Tune day on Feb. 12th if anyone is interested:
http://hobartsportingcarclub.org/pdf/2012/FEB%202012%20TEST%20&%20TUNE%20SUPP%20REGS.pdf
  • 1 month later...
I know its a bit late but do you have to join the LCCT to participate, cos on the calender it was down as Club Day Supersprint. I'm already a member of HSCC and don't really want to have to join another.
Also is Supersprint basically just time attack? I watched it at Baskerville a couple of weeks ago and was a bit confused because they were using the starting grid and starting all the cars at once.
Super Sprints is 4 cars on the track at a time, starting from the grid, fastest lap wins, you get like 4 laps.
Time attack, the track is open for like half an hour and you have to knock out a lap in that time with as many pit stops as you want.
Unless the event says something like (CLOSED TO CLUB) then any member of any CAMS affiliated car club can participate.
What exactly is the auto test day at symmons next month? looking at doing my first track day soon
I've honestly got NFI.
Their website doesn't help either
http://www.lcct.org.au/
  • 3 weeks later...
very much so :) it's just 4 cars on the track at a time, smash out a few laps and come in! heaps of fun and they'll put you against people who are getting similar times\levels of experience
Do it mate, you'll have the time of your life. Remember you have to get CAMS licence and club membership too, 99% of the time you can get it all on the day.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
